ABS Sensor
Old Sep 29, 2002 | 10:08 AM
Ideal's Avatar
Default ABS Sensor
Alright, to my knowledge, my ABS light is on do to the senser on my rear passenger side tire. Im not to shure on how to go about fixing this. Is it possible to do it yourself and what am i gonna need if i can do it.
p.s. I did run a search, nothing on how to fix, a couple just tell you how to find out.
Thanks
Jon
Old Sep 29, 2002 | 10:31 AM
Chiovnidca's Avatar
Default Re: ABS Sensor (Ideal)
I fyour sure it's a bad sensor, just replace it.
Old Sep 29, 2002 | 12:12 PM
Chiovnidca's Avatar
Default Re: ABS Sensor (honda_tech408)
okay that mother ***** is wrong on abs sensor.
Whats with all the name calling?
Old Sep 29, 2002 | 02:32 PM
Tee Es eX's Avatar
Default Re: ABS Sensor (Chiovnidca)
hhahahahahah...dude said M Fer for no reasonn..but mad me laugh..ahhah
Old Sep 29, 2002 | 02:46 PM
RotaryBzzz's Avatar
i think i know wats wrong wit ur car.
abs light is on because the abs pump on ur car run and the unit have ittermitent failure. go reset the ecm and see if the problem reoccur. if it reoccur listen for loud noise as the abs motor running. if there is loud noise, u have a abs motor problem go to the dealer have it fix.
do not mess around wit abs motor. or else u have no braking system. dangerous.
Ya man, what's with the name calling...especially from a noobie like yourself? Obviously, you didn't see that Ideal (aka Jon) already pulled the codes from the diagnostic plug and it told him it was the rear sensor.
Read the text before you start calling people names, (especially someone like Chiovnidca who is a real Honda technician and good contributor to this place).
Also, you CAN work with the abs system
Old Sep 29, 2002 | 10:12 PM
Ideal's Avatar
Default Re: ABS Sensor (RotaryBzzz)
Heh, how much do abs sensors run and how hard is it to replace it?
-Jon
Old Sep 30, 2002 | 12:33 PM
Ideal's Avatar
ttt
josh-roy
Jul 30, 2010 02:32 AM
BoBo Racing
Jun 5, 2008 01:31 PM
rollercosta123
Nov 25, 2005 12:09 AM
JDAN
Nov 17, 2004 06:08 AM
ghiboy
Aug 10, 2004 11:37 PM
