With cruise control on, SOMETIMES engine revs to 3K rpm when clutch pedal pushed down
ONLY SOMETIMES ill be using cruise control and push in the clutch and the motor will rev to 3 grand. doesnt really bother me just wanna know if it has happened to anybody else.
stock d16y8 with just an intake for mods thanks ...
That is normal. Just means that the engine was still getting gasoline injected right before you pressed in the clutch. I presume that it happens more when you do it while going up a hill or when the engine is under a load. Same thing will happen if you don't let go of the gas pedal when you press the clutch to change gears. The engine will rev the crap out of itself. Just means that the load got lighter and not much gasoline is needed to move the engine so it over revs.
BTW I don't own a Honda but I do own a manual GTO. Same thing happens to me, it just does it less 'cause it has more torque, less gasoline needed.
mrbassman001
13
Jun 16, 2010 03:18 PM
Mattgrimes
Honda Civic (2006 - 2015)
53
Aug 30, 2009 04:00 AM
