Slave cylinder for 98 gsr in 97 hatch
Old Sep 29, 2002 | 08:53 AM
mts20k97's Avatar
Default Slave cylinder for 98 gsr in 97 hatch
I tried a search but came up with nothing. Which slave cylinder and lines do I use? The slave cylinder from the hatch wont fit in the gsr tranny. The line and cylinder from the tranny isn't long enough to reach the hose that goes to the firewall. Anyone have any ideas?
Old Sep 29, 2002 | 09:18 AM
Jackson's Avatar
Default Re: Slave cylinder for 98 gsr in 97 hatch (mscivic12)
You can use your civic slave cylinder.
Old Sep 29, 2002 | 02:14 PM
Nameless RB26's Avatar
Default Re: Slave cylinder for 98 gsr in 97 hatch (Jackson)
someone on the forum made a steel braided line, and used fittings on the ends.
You'd have to search to find it...
Old Sep 29, 2002 | 10:50 PM
1 speedstar's Avatar
i was able to use my civic parts, maybe you should try again.
Old Sep 30, 2002 | 05:49 AM
Trey's Avatar
25 Year Member
Default Re: Slave cylinder for 98 gsr in 97 hatch (p r ! m o)
I resued all my civic hard and rubber lines. I din't even have to bleed the system. I just used the same slave cylinder as well.
I did have to reuse the brackets off the Civic tranny, on the teg tranny so the hardlines would bolt in place.
MidwestAutoWorks
Suspension & Brakes
Sep 16, 2008 05:49 PM
alscrx
May 9, 2008 04:34 PM
sloweh3
Oct 21, 2003 09:28 PM
deviant1
Feb 28, 2002 03:03 PM
Suprdave
Aug 1, 2001 07:45 PM
