Car sits over right tires more than left need help
Ok i have a 98 ls integra, the car has a salvaged title but i had the frame straightened also i have a new rack, new inner and outter tie rods, new front camber and have just had a 4 wheel alignment but the body of the car sits over the right hand tires more than the left hand tires i have no idea how to fix this its quite annoying. If you need pics just pm me and i can e-mail you some pics. pls help!
Thank you
Thank you
take a look at the width of the fenders, i have the same issue, looks like my drivers side is tucked in too far compared against my passenger side, only because of how the car was hit and the fender was pulled out to give the illusion of the car being straight.
the front wheels appear to be the same as the rear wheels, which is the primary concern, that is what you want to look at, as long as they are aligned correctly with the rear there shouldnt be any problem and your issue should be cosmetic as far as i can tell.
I'm betting whoever did the pulling on the frame machine screwed something up.
i think it depends entirely on how the car was hit previously, which would be something to look into, but when the wheels line up with each other from front to back its usually a cosmetic thing that makes it appear that way, the only other way i can tell would be to check to see how the wheels are positioned in reference to the frame of the car from underneath.
EkTurboHatch
Feb 3, 2003 09:25 AM
