MSD 2-step rev limiter
Old Sep 29, 2002 | 07:37 AM
HotRodTeg's Avatar
Default MSD 2-step rev limiter
does anyone have the directions to hook this up or does anyone no how to hook this up.
Old Sep 29, 2002 | 09:51 AM
Bontke's Avatar
Default Re: MSD 2-step rev limiter (streetracer)
Doesn't it have instructions? Might check MSD's website for instructions.
Old Sep 29, 2002 | 01:07 PM
jdmillusion's Avatar
can ypu explain what this rev limiter does?
appreciate it.
Old Sep 29, 2002 | 02:30 PM
Bontke's Avatar
Default Re: MSD 2-step rev limiter (jdmillusion)
http://www.msdignition.com/
Look at the website under Automotive/RPM accessories/Two and Three Step Module Selectors.
Basically when you stage your car you want to launch at a lower RPM. THis module allows you to press the gas all the way down and the RPM will only go as high as you want it...say 3,200 RPM. When the switch is released it will go to the next rev limit you set. That would be the max engine RPM you want.
Old Sep 30, 2002 | 12:11 AM
miller's Avatar
Default Re: MSD 2-step rev limiter (C5_ALLMOTOR)
does anyone out there know how to wire up a 2 step to stock ignition?
Old Sep 30, 2002 | 04:06 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: MSD 2-step rev limiter (vtecdoc)
Hondata.
Old Sep 30, 2002 | 08:48 AM
Urban Business
Guest
Posts: n/a
Default Re: MSD 2-step rev limiter (Mista Bone)
Hondata.
yeah well msd is still coo
quite ncie actually, fires every other cilly untill rpm is met.
143MYVTECEF
Jan 30, 2006 12:41 PM
_Endless_
Sep 8, 2002 11:39 PM
speedymon
May 8, 2002 04:22 PM
SEIKI
Apr 17, 2002 07:13 AM
