Changed my VSS & female connector still getting CEL ! pls help!
Hey guys, So i had a problem on my b20vtec. I had intermiddant readings on my speedo then it stoped working completely. Then 2 days before i was replacing my clutch it started working again. After clutch replacement it stopped working..
Bought another vss and also switched the female connector bc there was to much corrosion. Still getting a CEL light, speedo still doesnt work. NO Vtec :/
Any suggestions ? any advice would be helpful thanks guys
You have an electrical problem. It's time that you learned how to do some basic electrical tests. Can you get a digital multimeter?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/why-dont-you-have-multimeter-your-tool-box-2915627/
Yeah im sure my neighboor has one, he's building a 68 camero ss ground up. I'd love to learn, just no one ever wanted to give me advice haha.
Ok pulled fuse #15 . The metal prongs on the fuse are slightly colored brown but the inside looks good, i can take a photo of the inside of the fuse an upload , like i said not very good with electrical stuff
Yeah the inside of the fuse is intact , the only questionable thing for me is the lightly colored brown coating on the prongs of the fuse ... Is that how it should be ?
no it should look silver like bare metal.. I honestly can't say if its enough to affect it or not. Best thing to do is to get the multimeter and go from there..
ok, I should be able to get my hands on one tonight or tomorrow. This is to test the actual vss sensor for ground and positive charge ? not the fuse ? i can just put a new fuse to be safe to though yeah ? Thanks
Wdpfreak145
Sep 28, 2013 04:34 AM
renzis00
Mar 8, 2013 06:27 PM
allmotorEG-SI
Audio / Security / Video
18
Apr 9, 2005 10:26 AM
