Car will not shift into park
Hey guys I bought my car last year and I cannot get it to go into park. I have to put it in neutral and use the e brake every time I park it. I did a ton of body work and other mechanical on it and didn't get it on the road until late last summer so I just drove it and dealt with it. Now I am about to put it back on the road for the summer and I want to figure it out before it does.
It's a '93 Civic Si. I just checked with Honda and it does have an open recall for the adjuster pin but would that be the cause? The person I spoke with apparently doesn't have a clue about the recall or if it would be the problem. Or would it just the cable itself? Any info would be great.
Thanks
Thanks
I didn't know that 92-95 Si came with an automatic transmission. I mean if it's a 5 speed you can't put it into park just neutral and put the e-brake.
I hope not LOL
My car is an automatic from factory.
Well I just made my problem worse
I was fighting with the shifter and managed to get it into park but when I tried to get it back out it wouldn't so I put the key in the shifter lock and it came out. It then would go from park into reverse and back no problem but then it wouldn't go past reverse. My husband pulled the lever back and it finally came out of reverse and moves into any gear freely. Problem is it is now stuck in reverse no matter what position the shifter is in. I am about ready to blow this car up.
Hey guys I just wanted to thank you for your help and also give you an update. I replaced the shifter cable and it works great. For the first time since I bought the car I can put it into every gear.
Thanks again to 94EG8 for helping me out with the cable.
idewson
Nov 22, 2007 11:37 AM
