MAin bearing help
Old Apr 26, 2011 | 07:49 AM
Superqwak's Avatar
Default MAin bearing help
I am in the process of putting my gsr back togther, and i used my old main bearings to figure out the right main bearings to order.
i determined they were color Brown. After plasti gaugeing all mains were .001" so they are to big would my new color be yellow?
Old Apr 26, 2011 | 09:12 AM
bambam's Avatar
Default Re: MAin bearing help
What bearings did the block originally come with? Check the block stamps and crank stamps.
Old Apr 26, 2011 | 09:27 AM
pithor-c1's Avatar
honda OEM bearings color " red,greens or pink "!!!!! no browns,yellow,black or blue`s... good luck!!!
Old Apr 26, 2011 | 09:29 AM
turbodcxbro's Avatar
Your mains measured out to .001" clearance? Spec is .0015-.0017 I think...
Old Apr 26, 2011 | 11:48 AM
Superqwak's Avatar
clearance .001" yes
also i am using Ls crank in Gsr block. and yes with ls rods everything arp and machined for all the haters.
Old Apr 26, 2011 | 04:13 PM
Ok so your too tight, The way I read your post it was too lose. So you need to open up the clearances some, not much at all..
Old Apr 26, 2011 | 05:12 PM
Superqwak's Avatar
correct so which color i have heard that a looser bearing is better for a NA engine
Old Apr 26, 2011 | 05:50 PM
poodangity's Avatar
ok so i feel dumb asking this but i am having a really hard time finding the plastigage main and rob bearing specs for my b18b
Old Apr 26, 2011 | 05:57 PM
SR20S13's Avatar
from my understanding it all depends, you can run tighter clearences then a turbo setup, but you want it to be more on the looser end of the recommended specs if you plan to rev alot higher then stock
Old Apr 27, 2011 | 03:58 AM
Looser clearances give more oil volume in the bearings BUT less oil pressure overall, Honda engines like oil pressure, especially VTEC engines.
Most builders suggest staying with factory tolerances here, Honda did its homework and theres really no reason to change.
Old Apr 27, 2011 | 06:20 AM
mikesrex's Avatar
it's been a while but from the top of my head the clearances for the mains but I think 0.001" is good for all of them except for the middle one. I think the middle should be at least 0.0012". check the factory specs to be sure.
Old Apr 27, 2011 | 07:05 AM
kyosoeg6's Avatar
I have a set of acl duraglides that a barely used. The motor was fresh and blew up on the dyno then parted out.let me know if you want to use them
Old Apr 28, 2011 | 06:31 AM
Superqwak's Avatar
ok i think i am going to go with yellow for a more losser bearing
jorge59la
May 3, 2008 07:26 AM
boredracer408
Jan 3, 2004 08:22 PM
Teg15
Sep 1, 2002 01:12 PM
DamonBoost
May 14, 2002 10:52 AM
Brian_92GSR
Apr 2, 2002 01:53 PM
