Need some help !
Old Apr 25, 2011 | 02:51 AM
Jon-W's Avatar
Default need some help: added pics
alright , i had an accident and basically what happend was that i hit into a curb at maybe 50mph while my wheel was turnd to the right.
now my wheel is burst and is pushed pretty far back into the fender i was jus wondering if i have royaly ****ed my car or is is fixable without too much monies and hassle
any comments will be very much apreciated cheers.
Old Apr 25, 2011 | 05:40 AM
switchjv's Avatar
Default Re: Need some help !
probably need to get to a "u pull it" junkyard and grab all the front suspension components on that side. grab the axle too, just to be safe. thats probably the cheapest route. unless you find someone whos parting out the same car.
Old Apr 25, 2011 | 06:38 AM
98ekb16's Avatar
You basically have a 50/50 chance at a sort of easy fix. Some cars I've seen that did what you did just needed a lower control arm a strut maybe a new subframe. Others had bent suspension mounts on the frame and a tweaked frame. Get under the car with a tape measure everything first. That looks pretty bad, I wouldn't hold my breath on an easy fix.
Old Apr 25, 2011 | 08:22 AM
gqstatus05's Avatar
Take it to your mechanic so he can take a quick look at it and tell you what's damaged. I'm willing to bet that your axle is ****. U Pull it is your best bet in replacing it without breaking the bank. Hopefully you can do most if not all the work yourself.
How did you manage to do that? Were you facebooking?
Old Apr 25, 2011 | 04:02 PM
Yuyodrift91's Avatar
Lol that happened to me too. Except I was Drifting. Had to replace EVERYTHING.
Check your axle, strut, sway bar(if civics come with one) and your Upper and lower control arms.
You're lucky you had a forged wheel. I had a cast one and it literally exploded into 3 pieces. I only found 2.
Old Apr 25, 2011 | 04:23 PM
SolScifen's Avatar
like theyre all saying pretty much that whole side suspension should probably be replaced.
Old Apr 26, 2011 | 04:10 AM
Jon-W's Avatar
update :wheel off pics
Jon-W's Avatar
Thanks for the inputs.
Old Apr 26, 2011 | 04:44 AM
Jon-W's Avatar
haha, no it was dark and icey and 'U pull'?
Shiznit028
21
Dec 17, 2008 03:39 AM
19accord92
Apr 9, 2006 08:25 PM
JoHA
Oct 3, 2005 11:41 AM
CRXed
20
Sep 23, 2004 06:55 PM
Kellindal
Jul 31, 2001 04:21 PM
