Who is using the Precision Turbo 3431E Or 3231E
Old Apr 24, 2011 | 07:41 PM
CaliforniaDad's Avatar
No-Traction = Fun
Default Who is using the Precision Turbo 3431E Or 3231E
Who is using this turbo in a B18C1?
Thoughts?
Feelings?
Results?
Old Apr 25, 2011 | 07:41 AM
RealStreet's Avatar
Default Re: Who is using the Precision Turbo 3431E Or 3231E
We have sold quite a few. They are a good turbo for the price, and from what I've seen make about 325-350 on 15psi. They also come with a 1 year warranty.
Old Apr 25, 2011 | 08:34 AM
No-Traction = Fun
Oh really, I'm looking to be at 400 to the wheels so I guess this wont work.
Old Apr 25, 2011 | 08:47 AM
sc34dc4's Avatar
Assuming your setup will support it yes it can do it. It's rated for 545 crank hp
BUT are there better turbos to choose from yes. Talk to The Shodan he will be able to give you 50 options. I have this same turbo and I'm going for 400whp also when I retune. I'll let you know if I make it or not. I'm planning on upgrading to the sc61.
Old Apr 25, 2011 | 09:04 AM
RealStreet's Avatar
If you want 400whp, and want to stay in that price range. I would go with the Garrett 60-1 or Precision 6076
Old Apr 25, 2011 | 09:38 AM
No-Traction = Fun
Will both of those fit under the hood and still allow me to retain the AC and Power steering? here is the manifold I already have.
Old Apr 25, 2011 | 09:42 AM
RealStreet's Avatar
They are dimensionally bigger, the Garret has a 4" inlet, the Precision has a 3" inlet
Old Apr 25, 2011 | 09:58 AM
No-Traction = Fun
PM sent
Old Apr 25, 2011 | 12:09 PM
racebum's Avatar
400 at the wheels is dangerous on a stock gsr. safer on e85 but you're really pushing reliability looking out over time. i mean people do it, it's just a question of how long you'll live before a rod breaks or you spin a bearing
Old Apr 25, 2011 | 05:45 PM
No-Traction = Fun
Oh, but I am going all forged bottom end. Eagle H beams and Wiseco pistions Also ordered the AEM water/methanol kit
Old Apr 25, 2011 | 05:52 PM
sik96teg's Avatar
400 should be easy with the 3431E. Im pushing over 300whp at 10psi with this turbo.
Old Apr 25, 2011 | 05:57 PM
racebum's Avatar
myles did with either this or one damn near like it. turbo maxed out at 444whp on a stock gsr bottom end.
the only thing i'm wondering is with the manifold. generally if you're going after max power a ramhorn will beat down that cast manifold. but...that's not a bad looking cast piece. it's an inline pro copy of some sort, just depends on how it will flow.
Old Apr 25, 2011 | 06:07 PM
sik96teg's Avatar
Looks like the mani i have. I have the UGR cast mani.
Old Apr 25, 2011 | 08:50 PM
No-Traction = Fun
I'm not going for max drag race power more like mid-to top power. Basically i want to be able to put it to most street cars. Something thats quick but wont fall on its face on the fwy.
Old Apr 25, 2011 | 10:43 PM
No-Traction = Fun
What is this turbo? GT35R
http://cgi.ebay.com/ebaymotors/GT35R...ht_2652wt_1165
And here
http://store.max-redline.com/servlet/-strse-538/Detail
Old Apr 26, 2011 | 05:41 AM
TheShodan's Avatar
Moderator
Trying to cut corners again, eh? *Tsk Tsk*. Remember the phrase "If it looks too good to be true, you damn right it is!!"
Old Apr 26, 2011 | 07:32 AM
No-Traction = Fun
hahahha....Yeah I thought so
Old Apr 26, 2011 | 08:30 AM
sc34dc4's Avatar
A good name brand journal bearing turbo in used condition is going to run $300-600 depending on what it is. Yes sometimes you can stumble on a great deal but not a 35R for $300
Old Apr 26, 2011 | 11:43 AM
racebum's Avatar
a real gt35r in a to4e case that actually fits your application would run, what, $1500 or so? if you really have your heart set on 400+whp pony up $850 for a precision 6262 which also uses the t04e case and allows you to get the much needed 5 bolt exhaust flange. or, if you want to go straight bad *** you could do that gt35r.
it's just that you're talking about two pretty bad *** turbos and a $100 manifold that's not really optimal for them.
Old Mar 9, 2012 | 05:57 AM
KeseK24RSX's Avatar
Its not on a GSR but we just made 463whp @ 15psi using a PTE 3231e on a K20/K24
KMOD Performance Custom Turbo Kit
http://www.youtube.com/watch?v=cL8lflaEaQs
-Marquis
-KMOD Performance
Old Mar 9, 2012 | 08:31 AM
dcmatt's Avatar
Holy old threads Batman!!!!!!
Bonestock98GS
Aug 15, 2013 07:08 PM
si90rex
Dec 3, 2008 05:57 PM
CSRacing
Oct 19, 2005 05:27 AM
Radon_03
Jul 19, 2004 04:04 PM
