Transmission & Drivetrain Gearboxes, Differentials, Clutches
91 ef hatch axle prob.... READ READ READ all the big boys please read
Old Apr 24, 2011 | 06:31 PM
EF_NITROUS_FEED's Avatar
Default 91 ef hatch axle prob.... READ READ READ all the big boys please read
Ok this is my setup , I have a D15B Vtec with a DOHC ZC tranny and i cannot get the driver side axle to work correctly. I am using my stock axle with a 27 spline differential bearing end on it , the end is like 1/8 of a inch too short and will NOT lock into the diff. And I cannot use a half shaft. So i need to know if there is a axle that will work correctly . Or a axle end that will fit my axle/bearings that is a lil bit longer splines to lock in and keep from coming out and spray tranny fluid everywhere !!!!
Old Apr 25, 2011 | 05:47 PM
94EG8's Avatar
Seagull Management
Default Re: 91 ef hatch axle prob.... READ READ READ all the big boys please read
You need to run a halfshaft (IIRC the holes are on the back of the D15B Vtec block, i know for sure they are on a Z6) or you'll have to swap the 2 side gears (spider gears the axles fit into) for some DX ones.
Old Apr 27, 2011 | 04:59 PM
there is no place for a half shaft.... but its a d15 vtec was told it was a jdm not sure
not sure if its a mini me either
Old Apr 27, 2011 | 05:06 PM
94EG8's Avatar
Seagull Management
In that case you'll need to open the transmission and swap the two spider gears the axles are splined into for some DX ones then, and run DX axles.
Old Apr 28, 2011 | 11:41 AM
Mista Bone's Avatar
D Tranny Guru
have to swap the whole diff.
If you only swap the spiders, the axles will have a MAJOR wobble issue!!!!
I would contact Raxles and see if Marty can put different inner joints to solve this issue.
Old Apr 28, 2011 | 11:51 AM
94EG8's Avatar
Seagull Management
Really? I seem to recall some old post here, or maybe on D-series.org or the thezcr that said to do that. I don't doubt you at all, I'm just sure I read that somewhere.
Old Apr 28, 2011 | 01:50 PM
David @ Synchrotech's Avatar
Mista Bone is right. The diff housing on the ZC has a 28mm opening for the CV joint and the USDM SOHC D series diff has a 26mm opening. The whole diff will need to be changed.
Old Apr 30, 2011 | 01:09 PM
thanks, alltho thats not what i wanted to hear!!!!!!!!!!!!!!!!!
Old Aug 10, 2018 | 09:58 AM
rick_rabies's Avatar
I'm not Rick!
i tried to read it all. doesnt sound like you addres motor mounts? i could be wrong.
i know you have fancy stuff. but possibly one of the mounts is hobled out or loose?
also your fancy ITR trans...hows the dif in it? never heard of trans causing vibro though.
what about your fly wheel? oem weight?
if you think about it. what makes it shake is either the road or the motors power. starting at the flywheel...to trans. to axle to control arms then wheels....you worked on wheels and stuff. but go the other direction now.
ralphieg
Oct 2, 2012 06:36 PM
Cap'N Chronic
Jun 29, 2011 12:54 PM
EF_NITROUS_FEED
Welding / Fabrication
10
Apr 24, 2011 11:39 PM
eppymoto69
Apr 24, 2011 09:30 PM
boostd ls
Jun 4, 2009 10:14 AM
