91 hatch axle issue
Old Apr 24, 2011 | 06:23 PM
eppymoto69's Avatar
Default 91 hatch axle issue
Ok this is my setup , I have a D15B Vtec with a DOHC ZC tranny and i cannot get the driver side axle to work correctly. I am using my stock axle with a 27 spline differential bearing end on it , the end is like 1/8 of a inch too short and will NOT lock into the diff. And I cannot use a half shaft. So i need to know if there is a axle that will work correctly . Or a axle end that will fit my axle/bearings that is a lil bit longer splines to lock in and keep from coming out and spray tranny fluid everywhere !!!!
Old Apr 24, 2011 | 06:35 PM
AlfieRoach's Avatar
Default Re: 91 hatch axle issue
is ur 91 a dx std si?
Old Apr 24, 2011 | 08:09 PM
EF_NITROUS_FEED's Avatar
std with dx hubs
Old Apr 24, 2011 | 09:30 PM
eppymoto69's Avatar
STD hatch . With Si spindles , ... need 26 spline hub sude and 27 spline Differential side .... Bseries will NOT work , they are 25 spline, what else is 27 besides Accord ?
EF_NITROUS_FEED
Transmission & Drivetrain
Aug 10, 2018 09:58 AM
SIef9
Jan 15, 2012 05:13 PM
EF_NITROUS_FEED
Welding / Fabrication
10
Apr 24, 2011 11:39 PM
Momentum
Sep 2, 2010 10:06 AM
crxzcracer
15
Sep 21, 2005 11:17 AM
