Whining noise coming from timing belt area
Old Apr 23, 2011 | 10:56 PM
barryfaetheus's Avatar
Default Whining noise coming from timing belt area
Hi all:
I have a whining noise coming from the timing belt area on my 2002 Honda Accord (2.3 4 cyl). The the pitch of the noise changes with engine RPM. It is still there even when the power steering and alternator belts are removed.
I did have the timing belt/water pump replaced about 15000 miles ago (just a couple of days after I bought the car). The noise has been present ever since then. I can't be sure whether the noise was there before the belt replacement, as I'd just bought the car and wouldnt have noticed it yet.
I understand that symptoms like this can be due to the timing belt being too tight. But wouldnt it have stretched after 1 year and 15000 miles? Anything else in there that it could be?
I was planning to readjust the belt tension. Can I do this just with removing the top timing belt cover, or do I need to remove the crankshaft pulleys and bottom cover as well?
Old Apr 27, 2011 | 03:01 PM
Default Re: Whining noise coming from timing belt area
Folks:
Any idea about this?
thanks
Old Jul 22, 2011 | 10:50 AM
royscobra's Avatar
Iam no pro but it could be bearing failure
Old Jul 23, 2011 | 12:01 AM
holmesnmanny's Avatar
Yeah, if you didn't go OEM, there's always the possibility of that. Is it safe to assume that the place that did it gave u a one year warranty ? If so, take it back there.
Old Jul 23, 2011 | 12:13 AM
MAD_MIKE's Avatar
MM Gruppe B
Originally Posted by barryfaetheus
Hi all:
I have a whining noise coming from the timing belt area on my 2002 Honda Accord (2.3 4 cyl). ...
Did they replace the tensioners as well as the belts? Or just the belts?
Old Jul 23, 2011 | 09:47 PM
nus_dogg's Avatar
Timing Belt is too tight. You'll need to follow the adjustment procedure and it'll properly tension the t-belt and get rid of the whirring noise.
ceehris
Dec 13, 2006 10:10 AM
ekx4
Aug 28, 2006 12:18 AM
BOOSTEDgreeneg
May 25, 2005 12:51 AM
petrv
Mar 1, 2004 10:32 AM
petrv
Mar 1, 2004 09:56 AM
