My 93 civic hatch si -- CEL and idle problems
Old Apr 23, 2011 | 09:10 PM
nkcalvert09's Avatar
Default My 93 civic hatch si -- CEL and idle problems
Hey so my eg has been having some problems. i bought off some random guy and he did a swap and but a 94 b18 in it. First off the engine light is on. but ive found out thats pretty common with swaps. but main problem is after i start the car it idles extremely low. like around 300. but after i drive for a min it idles at around 1100. and randomly it like pulsates when im idling. im sorta new to the honda game so help would be greatly appreciated.. maybe its the iacv?
Old Apr 23, 2011 | 09:30 PM
NACvicSi's Avatar
Default Re: My 93 civic hatch si problems
First off check and see what engine code you're throwing. Just search the FAQ at the top of this board for a how to if you don't know. It could be a number of things. Have you tried cleaning your IACV?
Old Apr 23, 2011 | 09:57 PM
jdmb20eg6's Avatar
Check and clean out your idle control valve. Check ur vaccum lines too.
Old Apr 23, 2011 | 10:03 PM
lunareg's Avatar
a cel isnt common with a swap unless they did something retarded.. before anything check what the cel its throwing. You can jump the harness and read the flashes, or take it autozone and they will scan it for free.
The idle problem def sounds like you should at least take the iacv out and clean it with brake cleaner till it runs clear, and also check for vacuum leaks as stated.
Old Apr 24, 2011 | 12:44 AM
blackedEk's Avatar
check your iacv, clean it with carb cleaner, keep spraying until runoff is clear
also, check for any vacuum leaks, damaged vacuum lines
Old Apr 24, 2011 | 07:27 AM
Former User's Avatar
Default Re: My 93 civic hatch si -- CEL and idle problems
In the future, please create more informative thread titles -- edited.
Old Apr 25, 2011 | 06:48 PM
okay thanks everyone. and sorry i will describe the problem more. and thanks again
Dorkenheimer
44
May 23, 2015 07:51 AM
jrhcivak
Mar 29, 2012 08:48 AM
ThaBread
34
Oct 23, 2008 02:58 PM
1TwistedEG
10
Apr 3, 2005 05:14 PM
Integra_Boi
Sep 17, 2002 11:55 AM
