will ycp pistons fit on eagle rods? need help
i had a set of je pistons on my b20v but rings went out and pistons got messed up. low on budget and thinking about geting 84mm ycp pistons. wondering if it will fit onto eagle rods since the ycp is pressed fit wrist pin????
yes they will as long as the rods are for a b18(a)(b) b20... same brass bushing size: diameter and the ycp's are full floating design
ycp are full floating design but why does on the description says that its made to fit stock rods and has pressed fit wrist pins??? has anyone ever put ycp pistons on eagle rods before? i know they make custom i beam rods that will fit the pistons but my rods arent custom. jw bc i dont have the stcok rods and plan on reusing eagle rods.
you have to check the pistons everytime you get a set. i have an 84mm and an 85mm set right infront of me and the 84 is press fit and the 85 is floating. this is been happening with me at least for about 2 months now. i never know what pistons are gonna come in
