Weird B16 High RMP problem
Old Apr 23, 2011 | 04:57 PM
JDMEMone's Avatar
Default Weird B16 High RMP problem
So I had my car Dyno'd yesterday and I was happy with the results but I have two problems the first one is the at high RPM's over 8500 the rpm go to zero and bounce back at random from 8500 to 9500 any suggestions? the second is that everyonce in a while when I drop a gear or shift to the next it bogs really bad?
Thanks everyone!
Old Apr 23, 2011 | 06:51 PM
tempsohc's Avatar
Default Re: Weird B16 High RMP problem
Thanks everyone!
sounds like a bad connection in the distributor or a bad ignitor and or control module. All of these are easy and cheap fixes. Replace the electronics in the distributor and makes sure all the connectors are snug. I would check connections first.
I had a b16a that the tach showed 8k but the motor sounded like it was going to blow up. With a stock b16 computer i had no rev limiter and it showed 8k when i was really at 9.5k. It was a bad control module and ignitor.
Old Apr 23, 2011 | 09:03 PM
96dxB16's Avatar
Sounds like loose ecu ground on the thermo housing.
Old Apr 23, 2011 | 11:35 PM
JDMEMone's Avatar
where is there thermo housing? would it cause it to bog?
Old Apr 24, 2011 | 05:34 AM
N/A's Avatar
N/A
Purpose Built
If you cant find the thermostat, step away from the car and find a mechanic
HAPPY EASTER ALL
Old Apr 24, 2011 | 08:03 AM
JDMEMone's Avatar
Read too fast.... Its connected and grounded. ill take it out for a spin and see
Old Apr 24, 2011 | 07:18 PM
N/A's Avatar
N/A
Purpose Built
INFOR
Old Apr 25, 2011 | 07:29 AM
JDMEMone's Avatar
So checked all the grounds and they were good, I even added a ground and took it out for a spin, and it still has that RPM tach drop at about 9100 and a slight bog so Im gonnna put in a new cap and rotor, could it be that or the ignitor?
Old Apr 25, 2011 | 04:35 PM
JDMEMone's Avatar
k so I checked the dizzy and the screw that holds down the rotor had come loose and so I replaced it and it still does the same thing so I found another dizzy and we will see if it fixes the problem ( cant drive the car cuz its snowing like a mother F(*&er in UT)
Old Apr 26, 2011 | 04:15 PM
JDMEMone's Avatar
Update... i put in a new dizzy, and grounded my therostat housing to the firewall and its still doing the same thing??? any other suggestions I'm open to them all...
Old Apr 26, 2011 | 07:51 PM
mike11's Avatar
had the same problem in my crx. replaced the distributor with a brand new one off ebay and it solved the problem
Old Apr 27, 2011 | 03:24 PM
96dxB16's Avatar
I still think it is a ground issue. Maybe broken wire? Bad ground somewhere else?
Old Apr 28, 2011 | 06:52 PM
JDMEMone's Avatar
thats what my guess is. I grounded out the housing and still does the same **** ill try to post a video of whats going. mean while im going to check the cluster and tear that harness apart.
Old May 1, 2011 | 04:59 PM
JDMEMone's Avatar
K so a made a short video with my little problem... I personal think its a shift indicator cuz it does it at 9k everytime....
Comments welcome!
Old May 2, 2011 | 03:30 AM
N/A's Avatar
N/A
Purpose Built
Lol rev limiter??
Post your build so we know if your a complete ******* or not
Old May 2, 2011 | 02:30 PM
Si-vtay's Avatar
Originally Posted by N/A
Lol rev limiter??
N/A do you always come across as a dumbshit or just part of the time? OP asked for help and you have yet to provide useful or relevant information. Read the OP’s first post and follow along little kiddie… Would a Rev Limiter go from 9k to 0k and back again several times? If you think that’s what a Rev Limiter does, then I would recommend that you stick to adding only bolt on’s and race harnesses to your stock seating. Trust me, from the looks of it, whatever problem the OP has, its way over your head of expertise. GTFO
Old May 2, 2011 | 02:36 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
it can if its a fuel and ignition rev limiter..
Old May 2, 2011 | 04:37 PM
JDMEMone's Avatar
N/A its a B16 with 12:1, ported, with Pro 1's built by me! not bought like you!
I talked with the tuner today and he told me its a ignition cut. So is that why it does what it does? Here is a short clip
http://www.youtube.com/watch?v=AZFn9MjVtu8
Old May 3, 2011 | 02:44 AM
N/A's Avatar
N/A
Purpose Built
lol sad attempt to degrade me... congrats on being able to look thru my car thread and see that I only have boltons on my car so far. If you ACTUALLY READ thru it you'd know why it only has boltons so far.
Maybe YOU should read his post again
He has TWO problems
Both problems occur during a drop in rpms, so its probly the same issue. So shut the **** up and let the OP answer my question without clouding the whole thread with bullshit and not trying to help him yourself, yes I am being sarcastic about things but my only intention is to help him.
Built by you????? Man you couldn't even find your thermostat housing don't try and come talk like your some glorious engine builder. I've built more than one, and have reasons for keeping a oem engine in my car at the moment.
Where is your rev limiter set? What is it tuned on? Do you have a wideband?
The tuner you talked to, did he tune your car specificly? Does your tune include launch control? Do you have a knock sensor?
You have to be a lot clearer with what you have to receive the correct advice dude
If you have a tuner already the best bet is to bring it to him.
Lol and if the the both of you think that me trying to get the most out of a OEM built engine refects my knowledge or anything I've built in the past, feel free to continue bashing aimlessly
Old May 3, 2011 | 07:22 AM
DDTECH's Avatar
pro1's, shouldn't be reving that high, power doesn't carry in a b16 like that, i'd venture to say 8800rpms @ most. Stop reving it so high, you're just putting added stress on rotating parts.
You have ign cut on?? IF so, this is the problem, ign is very violent on the cut, and makes the tech go crazy as well as send a electrial charge through the system @ times..
check the tuning program, see if ign cut is what your using, or if both fuel cut and ign cut are on.. this is also the problem you say your having..its not really a problem its just the character of the IGN cut.
tatted91rex
Feb 25, 2006 09:37 AM
hyperlite1080
14
Apr 12, 2004 01:17 PM
CTR_EK9
Apr 19, 2003 11:04 AM
chirp3rd
Dec 9, 2002 03:45 PM
02WRX
Jun 30, 2002 08:03 PM
