crx with ls vtec. HELP!
So today i was taking the car out of the garage after i just got done putting all this work into it and it starts and idles great. No problem. But i start going and i get to a stop sign. Push in the clutch and as the car starts to slow down it stalls and shuts its self off. It starts right back up and i drive to the next stop sign and it does it again. I have the obd0 to obd1 harness but it was chopped to ****. And the computer im running is a non chipped p28. Can someone tell me what the hell is going on? it just started doing this
Edit: looked it up and figured out how to do it so i did and this is what i got.
Code 7: Throttle poition sensor
Code 9: Number 1 cylinder position sensor
Code 19: A/T Lock up control soleniod
Code 31: ????? No idea
Code 41: Heated oxygen sensor heater?
Idk it that helps but if anyone knows that would be great!
Code 9: Number 1 cylinder position syensor
Your answers are right in front of you. You have two issues:
1. Fix your CELs by using a multimeter to test connections from ecu to the malfunctioning sensors.
2. Get rid of the auto 1.6l sohc ecu youre using to run your dohc 1.8 manual motor.
what is the proper ecu to run with this motor in obd1? or obd0 cause i can just take the jumper off. and what about a multimeter? what does it do?
Thanks for the help guys
code 19 was weird because I thought he did say he pushed in the clutch at one point.
you'll need to get it tuned.
The reason your car shuts off is because of your codes. Fix the issues causing your codes. Its that damn easy.
you need to get ahold of a multimeter and start testing for continuity.
So today i went down in the garage and started messin around and found these two green wires the same color connected outside the harness. i started the car up and hit the brake and it started to die. unpluged it and hit the back and it stayed at the same out. FIXED! :D Thanks for all the input guys. Now it needs some fine tuning. Hope to have some vids up soon. shes a beauty.
ADAMnQuickRDX
May 7, 2009 11:30 AM
ys1civicsi
Jul 3, 2007 05:42 PM
CRseX84
10
Jun 19, 2004 05:57 AM
