oiling system for SC34?
Old Apr 23, 2011 | 10:50 AM
Stopsign32v's Avatar
Loved
Default oiling system for SC34?
What can I say, I'm a noob. And after talking to the techs at precision I'm scared to ask them this. What setup should I run for my SC34 turbo?
Old Apr 23, 2011 | 11:40 AM
B R Fittings's Avatar
Default Re: oiling system for SC34?
Use a -3 oil feed line with no restrictor.
Old Apr 23, 2011 | 11:47 AM
TheShodan's Avatar
Moderator
If under 70psi of oil pressure at cold start or WOT.
Old Apr 23, 2011 | 12:06 PM
Loved
Ok so other than buying an oil pressure gauge, installing it, and seeing how can I go about finding out if I have 70psi or not on cold start and wot?
Also what is needed to supply the oil to the turbo?
I think the best approach is to use a -3 feed line with no restrictor on the journal bearing turbos. Then if you notice some oil pushing out then add a restrictor immediately. If you under oil the turbo you won't know there's something wrong until its too late. If you over oil it you'll notice it right away and you can remedy it by adding a restrictor.
Old Apr 23, 2011 | 01:20 PM
TheShodan's Avatar
Moderator
I understand. But lately people have been doing just that as a rule of thumb and have been HORRIBLY wrong in these last 2-3 years. I agree, if there's no cause for alarm, there's no need to purchase one, IF they know what that pressure is and have tried the turbo out before hand. But its better to have one and not use it, then to need one, and not have one available.
80psi of pressure is really asking to have a .065" restrictor on most Garrett/Precision turbochargers. Borg-warners allow for a bit more pressure in the oil passages of their cartridges
Old Apr 23, 2011 | 01:44 PM
Loved
Old Apr 23, 2011 | 03:58 PM
TheShodan's Avatar
Moderator
A -3AN feedling going from the oil pressure sensor at the back of the block.
Google Stealthmode performance to get the right parts to feed your Honda turbo.
Old Apr 23, 2011 | 04:48 PM
sc34dc4's Avatar
I was told -3 no restrictor from Precision turbo themselves. I've been running my sc34 that way for over a year now and have not had any issues with it. It was previously on a friends car for over a year also with no restrictor and no issues. I don't have an oil pressure gauge hooked up so I don't know exactly what psi I'm at but it's not showing signs of leaking or smoke.
Old Apr 23, 2011 | 04:55 PM
Loved
Thanks! Got them in my favorites now. Will probably call them next week to order.
Old Apr 23, 2011 | 05:26 PM
TheShodan's Avatar
Moderator
Again, as stated in MANY threads here. Going by what they say is optional, as they don't know your particular oil pressure. For every 5 that have done fine without a restrictor, there are 5 more that have had issues. It's not an effing standard thing.. I easily get 10-15 PM per week over this question. I always have the same answer, regardless of company. CHECK YOUR OIL PRESSURE WHEN MAKING A DECISION
Old Apr 23, 2011 | 05:30 PM
sc34dc4's Avatar
I in no way said it was to live by. I simply gave my experience using the same turbo as he has in question. I'm not arguing your knowledge by any means. I've Pm'd you with questions myself and you were more then helpful.
Old Apr 23, 2011 | 05:34 PM
Its a good idea to just buy the restrictor when you buy the oil feed kit. That way you have it and can just install it if needed.
I have customers that do this a lot. An extra $8 for the oil restrictor is good insurance for your turbo.
Old Apr 23, 2011 | 05:51 PM
TheShodan's Avatar
Moderator
No problem. I hope I was able to help. I never get upset, just am a bit fatigued when others ask this question repeatedly. I'm just sooo surprised we don't have a "sticky" on this topic.
Old Apr 24, 2011 | 11:41 AM
sc34dc4's Avatar
Trust me I know the feeling. Every time I see another thread about crankcase venting I just shake my head. It's been beaten to death on here over and over.
Old Apr 24, 2011 | 04:27 PM
hondatuner020's Avatar
dont mean to jack this thread but i saw no point in making a new topic for a similiar question.
im running a b18c1 with an oil pressure sensor running off of a sandwich plate
im currently untuned on a base map running a precision 5431b and have only revved it to 4500..... This was the peak reading for partial throttle around those revvs.
This seems high right? should i buy a restrictor?
Old Apr 24, 2011 | 04:39 PM
TheShodan's Avatar
Moderator
Are you seeing any signs of oil leakage, such as oil in the exhaust, downpipe, or coming out of the compressor? If not, then rock on.
Old Apr 24, 2011 | 04:47 PM
i ran an sc61 last year with the same set up and i didnt have any blue smoke or anything, but when i removed it i did notice a what seemed to be a slight residue when i shined a flashlight in the compressor housing.... is there a downside to running one just in case?
Old Apr 24, 2011 | 05:02 PM
TheShodan's Avatar
Moderator
If you run the wrong size, you could starve the turbocharger. I'd use a .065" if you're worried that much.
Old Apr 24, 2011 | 05:56 PM
Loved
Is that a prosport gauge?
Old Apr 24, 2011 | 06:14 PM
LightningTeg's Avatar
Community Builder
Looks like glowshift.
Old Apr 24, 2011 | 06:27 PM
correct
Old Apr 24, 2011 | 07:03 PM
Loved
Are they decent gauges? I was looking at the Prosports
Old Apr 24, 2011 | 09:12 PM
Community Builder
They're "ok". I had a set for a couple years in my integra. Felt kinda cheap. I really like how well it matched the integra gauges though.
After LEDS
lemonracer
Sep 17, 2013 01:11 PM
4tika4
Mar 28, 2012 04:41 AM
xkrazyxjbrkerx75
Aug 9, 2011 02:47 PM
wade
Oct 10, 2004 07:38 PM
GruvyTune
Feb 5, 2002 03:27 PM
