Oil Ristrictor
Old Sep 17, 2013 | 08:43 AM
lemonracer's Avatar
Default Oil Ristrictor
I need to know what size oil restrictor to use on my turbo setup. It is a Garrett TE27 (T28) turbo. I have a 3an feed line and a 10an drain line. My oil pressure on cold start is 85-95psi and once warmed up it is 75-85psi. I had the crank cut, new bearings installed and new oil pump. That is why my oil pressure is higher. Thanks for the help.
Old Sep 17, 2013 | 10:04 AM
justYncredible's Avatar
It's wU to the sOLdiEr!
Default Re: Oil Ristrictor
I believe the magic number is .065 but that shouldn't be needed with a 3an line but you could use it still
Old Sep 17, 2013 | 10:09 AM
Turbo-LS's Avatar
IMO you should always be running a restrictor. .065 for journal bearing.
Old Sep 17, 2013 | 10:56 AM
TheShodan's Avatar
Moderator
I would agree with this for the Journal bearing T28. I believe it uses a 1/8thNPT fitting for that cartridge. with that high of an oil pressure at cold start, .065" or .060" would be just fine.
Old Sep 17, 2013 | 01:11 PM
lemonracer's Avatar
Thank you for the help guys.
deeboii2014
Apr 1, 2015 05:48 AM
Stopsign32v
Apr 24, 2011 09:12 PM
RTW DC2R
May 21, 2006 01:50 PM
screen_name
Apr 23, 2005 07:22 AM
wade
Oct 10, 2004 07:38 PM
