CRX stage 3 clutch - pedals/cables breaking.
Old Apr 22, 2011 | 02:04 PM
Non Phixion's Avatar
Default CRX stage 3 clutch - pedals/cables breaking.
First my cable snapped then I replaced the cable.
Then my clutch pedal started tearing, so I took the pedals out and welded the bracket where it was tearing, then 2 weeks later it started tearing in a different spot.
Put new pedals in, I can't find any tears on the new pedals but I have to keep tightening the clutch cable in order to be able to shift smoothly and not have to jam it into gear.
Is there anything anyone can recommend?
I was thinking maybe something needs lube so there isnt so much strain on the cable/pedals?
Old Apr 22, 2011 | 02:28 PM
.Manny.'s Avatar
Touching My Member
Default Re: CRX stage 3 clutch - pedals/cables breaking.
What engine and trans combo?
Old Apr 22, 2011 | 02:38 PM
B16a2 and CRX SI Lsd tranny
Old Apr 22, 2011 | 02:52 PM
.Manny.'s Avatar
Touching My Member
Get rid of the clutch. Overkill for your setup unless you're tracking it and using slicks. If it's a daily, try something like an exedy stage 1. Mine held up to my old B16 on nitrous and its now on my B20vtec.
Old Apr 22, 2011 | 02:55 PM
XJorXdanX's Avatar
I had a honda civic wagon with a itr transmission and a b16a in it, 7lb flywheel and stage three clutch
my pedal snapped to the floor. haha.
I just swapped an rt4wd pedal assembly and welded brackets into it.
rt's have stronger pedals.
Old Apr 22, 2011 | 02:56 PM
I know that the clutch is too much but I was thinking of keeping it in there for when I go turbo at the end of this summer. But I just might have to get rid of the clutch simply because of this problem anyways.... .
Anyone else heard of this problem due to stage 3 clutch?
Old Apr 22, 2011 | 03:02 PM
.Manny.'s Avatar
Touching My Member
it's common when using heavy pressure plates. You're gonna snap ****, regardless. You can beef up the pedal assembly and that'll hold up, but you'll be going through cables often. Either convert to hydro or lose the clutch.
Old Apr 22, 2011 | 03:05 PM
So you recommend exedy stage 1? Will that still be fine if I go turbo?
Old Apr 22, 2011 | 03:09 PM
.Manny.'s Avatar
Touching My Member
Nope. Your best bet is to convert over man. Gotta pay to play. Check out Suja1 for their conversion kit.
Old Apr 22, 2011 | 07:10 PM
blaak-crx's Avatar
I got a Stage 1 Exedy, I got problems shifting now. Got a slightly mod B16 with Type-R tranny. Happens only when it gets hot from a Time Attack or a 20 minute lapping... I have to keep adjusting the cable tension....not normal. Going back to Type-R OEM clutch which I had before and had zero problems.
Old Apr 22, 2011 | 08:50 PM
Do you think the Suja1 ef conversion kit will work in my 88 hf crx?
Do you know how difficult it is to convert?
Kid_SiR
Jul 16, 2011 12:10 PM
HondaracerS2000
Classic Hondas
13
Jun 4, 2009 04:41 AM
88'CRXsi
Dec 31, 2008 01:50 PM
88crxdxfastwhip
Sep 4, 2005 09:18 PM
