Bumper to fender bolt/screw
Old Apr 22, 2011 | 10:33 AM
Dekorum's Avatar
Default Bumper to fender bolt/screw
Does any body know any tricks to get the plastic grommet to stay in the fender so you can use the OEM phillips screw to hold the bumper to the fender?
The plastic grommet I am talking about is number 11 in this picture
My driver side fender was using some crappy metal bracket which rattled and didn't hold the bumper on close enough to the fender. So I bought a new plastic grommet/screw so I could put it the bumper on the OEM way like the passenger side, but I can't get the plastic grommet to stay in the hole.
Old Apr 22, 2011 | 10:43 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: Bumper to fender bolt/screw
superglue.
epoxy.
jbweld.
Old Apr 22, 2011 | 01:30 PM
Dekorum's Avatar
Anything else? I don't want to jump into putting superglue on my fender unless its my last option.
Old Apr 22, 2011 | 01:35 PM
grumblemarc's Avatar
The Grumpiest
With that piece on the front it kept popping out so I zip-tied it until I could figure out something better. Didn't like having to do it but 2 of them hold on pretty well and isn't permanent.
Old Apr 22, 2011 | 03:50 PM
TwoFaced's Avatar
^x2
Old Apr 22, 2011 | 03:53 PM
lunareg's Avatar
lol I came in here to see what part it was too, my bumper is zipped tied on one side. it works obviously, but its not really lined up right lol
Old Apr 22, 2011 | 04:46 PM
civicsmoke's Avatar
make sure the lip on the fender is flush with the bumper, then get yourself some stainless steel bolts and nuts, use washers on both sides.
Old Apr 22, 2011 | 05:06 PM
HaZyEk9's Avatar
^x3
I have basically my whole front end zip tied and you arent even able to tell the diffference. Get the heavy duty black ones with the metal lock and youll be good!!! Dont use the cheap white ones you can see and they arent as durable. Atleast until you figure what else to do,but ull prolly end up leaving it! Human instict
Old Apr 23, 2011 | 12:17 AM
s13hero's Avatar
This is what I did too.
Old Apr 23, 2011 | 09:00 AM
Dekorum's Avatar
You used an actual nut? Thats kind of hard to have to hold that with a wrench while you are tightening the bolt, since the area is pretty tight to work in. Most people use the metal bracket with the nut welded onto the back, like in the OEM lip hardware kit.
Old Apr 23, 2011 | 09:14 AM
EJ1civic coupe's Avatar
then if you dont wanna do that option then why dont you buy the OEM hardware kit..duh
theres so many options out there on what to do..the little white plastic peice isnt gonna last for ever..mine eventully started coming out as well and all i did was use the nut and bolt option..its not hard at all to get in there and tighten it up if you kno what your doing
Old Apr 23, 2011 | 09:17 AM
lunareg's Avatar
yeah if you take the corner light out, its easy as hell to get at it.. I just went for the zip tie since its easy to cut it out if you need to get your bumper off, lol
Old Apr 23, 2011 | 09:18 AM
Dekorum's Avatar
Ok, cool. Just trying to see some ideas as to what others are doing.
Old Apr 23, 2011 | 09:52 AM
also turn the wheel inwards so you can get more leverage if you wanna use bolts/nuts..and zip ties are easy as hell to..5 screws up top..2 bolts on bottom and 2 snips on the sides and there you go the bumper is off less then 3 mins
Old Apr 23, 2011 | 02:44 PM
sde780's Avatar
The more you screw the screw in, the better the plastic clip holds. Might want to make sure the fender tab that it goes in isn't bent. If it is, bend it back
Old Apr 23, 2011 | 02:55 PM
Dekorum's Avatar
Yeah thats one of my problems. My fender tab is so mangled. Its just just a staight tab thats bent down. Bending it back still leaves it almost like a piece of paper that was once crumbled. I can't figure out how to straighten it completely since I only have a needle nose plier.
Old Apr 23, 2011 | 03:45 PM
Dekorum's Avatar
To get an idea of what I'm talking about...
Good side
Bad side
Old Apr 23, 2011 | 03:55 PM
C4_Gsr_civic's Avatar
Geeze does evrybody use zip ties? i have them too lol
Old Apr 23, 2011 | 05:24 PM
sde780's Avatar
Just use a ziptie. I used a huge plier that exhaust shops use and got mine somewhat straight, but it still wanted to pop out with my fiberglass bumper
RedZoneOS
13
Jul 9, 2013 01:19 AM
oMek
Jan 18, 2007 05:33 AM
gsxr750jah
Honda S2000
Jun 11, 2006 10:28 PM
grlstockb18c1
Jun 11, 2004 01:05 PM
turbocoupe
Apr 6, 2003 05:15 PM
