Tranny Conversion for Civic 96-98 EK3 Vi
Old 01-24-2011, 06:20 AM
apachexihuanni's Avatar
Default Tranny Conversion for Civic 96-98 EK3 Vi
Hi Honda-Tech Gurus,
Currently I'm looking for tranny conversion from CVT to Manual gearbox.
For the conversion process, what parts require for conversion changes.
Need your advise
Old 04-20-2011, 05:33 PM
rinker_21's Avatar
Default Re: Tranny Conversion for Civic 96-98 EK3 Vi
Well im currently doing this exact swap right now with my 1998 Civic HX. you will need the following items. A manual transmission (D-Series) out of a 96-2000 it will be tagged "S40". you will also need the entire pedal assembly. Linkage rods with shifter bushings and seals and boot. A manual starter with the bolts (they are longer then the automatic ones). Flywheel, clutch kit(with buying all that your better off buying a new slave cylinder) you will also need the clutch master cylinder with the lines. An ECU out of a manual car is not a absolute need but it'll will make the engine run better supposedly i haven't had to install mine yet.
Old 04-20-2011, 11:22 PM
Hi rinker_21,
Really thankful and appreciated with your response on my thread.
You have mentioned earlier is excatly 100% on what I have been go through.
Currently i still running with Auto ECU in which there is some problem with it.
My 3 stage VTEC was not functioning and re-wiring was required. Do you have any idea on the re-wiring on the Auto ECU in order to allow 3 Stage VTEC get it functioning.
Need your advise for that
Old 04-23-2011, 08:05 PM
rinker_21's Avatar
Im sorry i do not have an answer for you on that.
Homotor
07-25-2009 04:42 AM
jack-gtir
06-23-2007 08:57 AM
helpisneeded
09-18-2005 01:11 PM
Regulator
10-31-2002 12:29 PM
Tony the Tiger
06-25-2002 08:56 PM
Quick Reply: Tranny Conversion for Civic 96-98 EK3 Vi
