CX Racing turbo stuff. Whats everyone think?
Old Apr 22, 2011 | 08:59 AM
cmdrep328's Avatar
Default CX Racing turbo stuff. Whats everyone think?
I'm boosting my hatch, and have been looking at some cx racing parts. I want to hear everyones opinion/stories about their products. How long does the stuff last? is it fairly strong? I know you get what you pay for, but I've heard from a friend they have good stuff. Just need some more opinons and thoughts before i order anything! please post! Looking at their intercoolers, turbo, couplers ect. Thanks ht!
Old Apr 23, 2011 | 04:00 AM
Natural Aspirations's Avatar
Default Re: CX Racing turbo stuff. Whats everyone think?
You simply can't cheap out on turbos, cheap is cheap.....
Most of all the cheap parts are all the same crap rebadged, none of it is "good" most of it is barely usable for long periods of time.
Old Apr 23, 2011 | 09:56 AM
Mugencrxsir1's Avatar
There intercooler kits, oil coolers, and radiators are good... Everything else I have no experience with, but plent of people can vouch that their intercooler's are just as good as the high dollar stuff... I've personally used 3 different ones, and will pick up an oil cooler from them as well!
But when it comes to turbos, you should stick to the name brands as Ebay turbos are hit or miss. Some blow up the same day installed, others run 20,000+ miles without issues... But why risk it when Turbonetics, Garrett, etc... All have turbos for under $700 that will fit your needs and come with a okay warranty.
Old Apr 23, 2011 | 09:59 AM
ryguy2588's Avatar
You can use the intercooler, charge piping, and the radiators as mugencrx said. I wouldn't use anything else.
Old May 23, 2011 | 05:49 PM
cmdrep328's Avatar
Thanks everyone! I'll for sure go with cxracing for an intercooler and such. how important would an oil cooler be for a boosted stock block/head b16 street car? looking to make around 275-300
Old May 24, 2011 | 04:00 AM
sanman000719's Avatar
650/410 on there piping, and intercooler no problem
it does get high on the iat's though
Old May 24, 2011 | 09:38 AM
sethm's Avatar
I haven't seen many people run them for those power goals. I would put that money towards the turbo.(I know I know, beating a dead horse)
Old May 24, 2011 | 10:50 AM
303Turbos's Avatar
The china turbos can be ok, but the real problem is that they are not engineered to be performance turbos, so they wear out too fast. They are usually t3 or t4 or a combination of each, but they don't run 360 degree thrust bearings like a turbonetics turbo does, and the build and balance tolerances are usually pretty loose.
The real way to go is to find a complete kit, put it on, and run it until the turbo dies. If you get a good enough deal, the pipes, intercooler, BOV, wastegate, etc., are priced right and the turbo is pretty much free.
Old May 24, 2011 | 01:46 PM
93CX's Avatar
275whp @ 11psi on a eBay 50 trim be prepared to leak oil past the seals constantly. Small price to pay when you're getting a $90 turbo
Old May 24, 2011 | 07:01 PM
MR.johnson's Avatar
i would rather not chunk turbine wheel into my charge pipes and intercooler. build it right the first time.
Old May 25, 2011 | 10:20 AM
303Turbos's Avatar
That would never happen, unless you got a chinese turbo that didn't even use inconel in the turbine wheel or if you got a chinese turbo that had metal shavings in the oil feed hole. What are the odds of that ever happening?
Old May 25, 2011 | 11:39 AM
BigMike0147's Avatar
I've used their intercooler piping and nothing wrong with it. Just adding my $.02
Old May 25, 2011 | 12:12 PM
wantboost's Avatar
Who is Mr Robot?
my buddy is sponsored by them and runs a cx turbo on his 1.5jz in his s13 and competes in FD... hasn't had an issue yet
Old May 27, 2011 | 08:17 AM
303Turbos's Avatar
I just don't like chinese turbos, too hit or miss for me. There are hits, no doubt, but most of the ones I see get worn out pretty quick.
rsangha13
Mar 24, 2013 07:07 AM
WeakSauce92
Apr 6, 2010 09:45 AM
integraracing91
Sep 23, 2007 05:16 PM
