CEL codes
Old Apr 22, 2011 | 07:57 AM
jmacsss's Avatar
Default CEL codes
hello, 99 si, b18c, p2t ecu, getting a code p1259. vtec system malfunction. should i replace the entire solenoid? my tps seems to be giving me problems too. car sorta decides its own position like its getting the wrong signals. it will take off and sorta hold itself back at the same time. anyone else have similar problems?
Old Apr 22, 2011 | 08:05 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: CEL codes
i thought obd1 and 2 had dif sized gears for VSS or sumthing. not sure.
si ecu aint gonna cut it. you need the correct ecu
clean your vtec seloniod. and reseal it with hondabond
Old Apr 22, 2011 | 08:07 AM
jmacsss's Avatar
im working on getting a p28 with a stepdown harness and getting tunned. what are the procedures for cleaning it?
Old Apr 22, 2011 | 08:09 AM
I'm not Rick!
3 10mm bolts. put a rag under the job, oil will come out.
your 3 wires could be bad.
check the vtec ground.
clean the filter in the selonoid when you have it off. use brake cleaner. and reseal it back on.
unplug the plugs.
3 bolts.
pry off
Old Apr 22, 2011 | 08:13 AM
jmacsss's Avatar
gonna go try that now. thanks man
sethmoman
21
Jan 12, 2012 08:33 AM
lamafia781
Jan 20, 2011 12:15 PM
EJ8VTEC
15
May 15, 2006 11:02 AM
zeroek
Oct 16, 2005 09:45 AM
singlecamrocket
Oct 28, 2003 10:27 AM
