ls/vtec problem help plz!!!
There are several things that you need to check. You obviously need a VTEC Ecu, did you run the oil line and tap the head properly? Also check to see if the dowel pin and o- ring under the middle cam cap is there. If all else fails check the oil pressure at the head and the block.
bigislandc2
Sep 2, 2006 10:37 PM
clos0821
Sep 4, 2004 12:57 PM
