ls/vtec problem help plz!!!
Old Apr 21, 2011 | 09:00 PM
carlossolorzano's Avatar
Default ls/vtec problem help plz!!!
i have a ls/vtec im running a obd2a ecu is a 1996 but my vtec is not kickin can it be the ecu?
Old Apr 21, 2011 | 11:05 PM
mouab18c1's Avatar
Default Re: ls/vtec problem help plz!!!
First of all you need a chipped obd1 ecu with a proper basemap.
And for your Vtec issue, any cel? Enough oil pressure?
Old Apr 22, 2011 | 08:41 AM
Mr. EG's Avatar
There are several things that you need to check. You obviously need a VTEC Ecu, did you run the oil line and tap the head properly? Also check to see if the dowel pin and o- ring under the middle cam cap is there. If all else fails check the oil pressure at the head and the block.
carlossolorzano
Nov 26, 2010 10:03 AM
hondakrazy
Oct 5, 2008 02:16 PM
B18c1turboedEK
Jun 6, 2007 10:07 AM
bigislandc2
Sep 2, 2006 10:37 PM
clos0821
Sep 4, 2004 12:57 PM
