Help Boosting an B16a on Dominican Rep pump gas (84 oct the best available here)
Old Apr 21, 2011 | 08:24 PM
KamikazeDR's Avatar
Default Help Boosting an B16a on Dominican Rep pump gas (84 oct the best available here)
Hi mates first of all sorry for my English but here is the deal
I'm planning to Boost my Civic 98 JDM B16a SIRII for an street daily drive setup hoping to get at least 210-220 whp on pump gas knowing that the best pump has in this country barely hits 85 oct and here comes the questions
-Which compression should i go with this setup that not compromise my spool time a lot
-Which size of turbine/compressor
-Its necessary to replace the stock rods??
-Injector size
-Can i use stock integra GSR piston that make my comp 9.1?
-An stronger oil pump its gonna be necessary?
Thanks for take time reading this belive its gonna help me alot i have spend days reading diferent post and info in this forums but remember that im in a different case due to the bad pump gas that i have in my country
Old Apr 22, 2011 | 05:18 AM
wolve's Avatar
Default Re: Help Boosting an B16a on Dominican Rep pump gas (84 oct the best available here)
dajum, 85 octane.......
LS pistons and a small snail will spool decent and make 200+ whp
no need to replace ords or oil pump
yes you can use the GSR pistons
injector wise, the dsm 450's will be more then enough
4-7 psi on a small snail should get you there
Old Apr 22, 2011 | 08:28 AM
KamikazeDR's Avatar
Snail???
I did a little research about the octane in our pumps gas and the best i can its 82 octane then 91 101 an 109 on vp racing fuel but im trying to run on pump gas.
Soo wich size specific turbine A/R, trim ect???
I will be able to run on 10 psi??
Thanks
Old Apr 22, 2011 | 08:41 AM
TheFrog's Avatar
Just get a good manifold 450cc injectors 50 trim turbo and s300 and make 200+hp under 12 psi.
Old Apr 22, 2011 | 11:30 AM
92db2gs-r's Avatar
just get a water methanol kit. it makes it to where you can run low octane.
http://www.aemelectronics.com/water-...ction-kits-23/
Old Apr 22, 2011 | 01:02 PM
B6tPoweredMx3's Avatar
How is the gasoline rated at your pumps? There are several different variations...
Old Apr 22, 2011 | 03:42 PM
Bartman201's Avatar
must pump in the Dominican Republic have a lot of water in them gas is not that regulated out there. loco if all you want is 230whp just get some 450 or 500 injectors leave the motor as it is no changes just make sure you get a good tune.
Old Apr 22, 2011 | 05:42 PM
boostedcivicsir's Avatar
Mr. Badwrench
i love the just use meth replies, im not saying it doesnt work, i am saying what happens when it runs out/fails?
meth is another bandaid.
is there a way you can get http://torcoracefuel.net/pro-accelerator.html ??
atleast with this if you run out of gas, you know you are out of gas. not like running out of meth.
again just my 2 cents.
Old Apr 22, 2011 | 08:02 PM
KamikazeDR's Avatar
Thank yall for your response im not going meth im just gonna use a an octane booster like SIR said and get it well tuned on Hondata but i cannot leave the compression so high because remeber its an SIRII 10.4.1 its to0 high for this crappy gas pump
My last cuestion
Will my engine with 8.5.1 pistons will spool fast an Garret .48 a/r turbine and achieve my goal of 200+ hp??????? or i should use instead the 9.1.1 pistons or higher comp
Note i already have those pistons and turbine in my hands thats why i want to know if its ok to use them
Old Apr 22, 2011 | 08:14 PM
Bartman201's Avatar
My last cuestion
i used to live in santiago and my i had the same setup you have. i had 9:1:1 srp pistons on my setup and it worked good down there. you can use the turbo on the saab's they are small and easy to find in DR.
Old Apr 22, 2011 | 08:54 PM
KamikazeDR's Avatar
Wow man u should add me to ur msn Kamikaze_rd so u can answer a few cuestions like how many hp did u get and ur setup
Old Apr 22, 2011 | 09:06 PM
Bartman201's Avatar
just pm me your question ill be more than happy to help you.
hondapimp125
Jan 22, 2010 06:59 PM
LudeToAHatch
Dec 24, 2007 01:02 PM
KHAN SHOP
Nov 15, 2007 11:58 AM
lsvtechatch92
May 24, 2007 12:53 PM
a1320addict
Oct 15, 2005 12:46 AM
