Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
idle revs up then dies down over and over.
Old Apr 21, 2011 | 12:46 PM
ghostcivic's Avatar
Default idle revs up then dies down over and over.
2004 civic 1.7l we just swapped the motor yesterday. the motor was running good before we pulled it. im not sure where to look. i have heard people say clean the iacv with carb cleaner but not sure what part to clean on it? i have heard other honda's idling this way... btw it only idles this way in neutral or park. in drive it feels like its high but smooth. any ideas im all ears.. oh and yes i have checked all vacuum lines and electric connections.
Old Apr 21, 2011 | 05:10 PM
lazlong's Avatar
Default Re: idle revs up then dies down over and over.
Scan it for codes.
The IACV is on the throttlebody, it's #1:
Old Apr 21, 2011 | 05:17 PM
ken9's Avatar
Do you have any ceL???
Old Apr 21, 2011 | 09:52 PM
jmvtec05's Avatar
mine was doing the same thing when i swapped motors too... i put in on a scanner and the TPS (throttle position sensor) code came up... luckily, i still had my old motor, so all i did was swap throttle bodies instead of just the sensor because i didn't have the tool to take out the sensor. everything is fine now so i would definitely check that out.
Old Apr 21, 2011 | 11:55 PM
lazlong's Avatar
^^ Yeah, the TPS is riveted in.
Anybody taking bets on what sensor isn't connected or whether it's the ELD?
Old Apr 24, 2011 | 09:33 PM
It Wasn't Me's Avatar
Have you tried resetting the ECU and doing the Idle Relearn?
It's worth trying.
Pull fuse #6 out of the fuse box under the hood. Wait 30 seconds, then reinstall it.
- Turn everything electrical OFF. (radio, wipers, a/c, lights, etc etc)
- Start the car and hold the idle at 3,000 RPM until the radiator fan comes on, or until the coolant has reached 194 degrees.
- Take your foot off the accelerator and let the car idle for five minutes. (if the radiator fan comes on, do not include its run-time in the five minutes)
Your idle should be 700 RPM (+/- 50)
You can also try removing the IACV and cleaning it with carburetor cleaner. Just remove it and clean everything inside it. Also check to make sure there isn't any buildup in the throttle body.
Old Apr 25, 2011 | 07:37 AM
95eggsr02em2k20's Avatar
do u think it might have a air pocket in the coolant system does it get good heat?
Old Apr 25, 2011 | 01:24 PM
Pothole987's Avatar
This most times happens when people fill the radiator up and put the cap on it without bleeding it.
Did you bleed the system?
Old Jan 3, 2012 | 05:24 AM
IVI's Avatar
IVI
iacv : just clean the two ports with carb cleaner. carbon builds up inside.
my thought would be double-check tps and make sure no vacuum leaks.
Type 56
Nov 3, 2022 08:56 AM
Throwback23
May 4, 2010 09:33 PM
spintboy
Jan 31, 2008 08:06 PM
92ehatch
Nov 13, 2006 02:33 PM
LyFeWoRx
Aug 22, 2004 11:22 AM
