just bought a type r motor. RHD harness question
Old Apr 20, 2011 | 09:38 PM
streetglowjoe's Avatar
Default just bought a type r motor. RHD harness question
my buddy just got a type r from hmo. came with a rhd harness. is any possible way to make it work in his teg? his dad insists that it wont work. any way to make it work
Old Apr 20, 2011 | 09:47 PM
mark@silbernage's Avatar
Default Re: just bought a type r motor. RHD harness question
It's not "if", it's how.
Just got mine running this evening.
Old Apr 20, 2011 | 09:49 PM
well i did a little bit of wire re arranging and legnthened the chassis harness a little. it looks as if it will plug in but the kids dad insists that it just wont work at all.
Old Apr 20, 2011 | 09:58 PM
A little more info would help.. what MMY (make, model, year, etc) are you putting it into?
A little more info on the engine, what year B18C (R)? Manual transmission (which one)?
The JDM engine will be missing the CKF sensor, VTEC oil switch, and EVAP controls.
You can bypass the first two, and depending upon what you end up choosing for an ECU either live with or ignore the EVAP. Of course, if you're in love with the EVAP controls there are ways to adapt also - but probably more work.
In my case, I found a used USDM harness (out of a GSR in my case) - and modified it (lengthened the IAC lead), cleaned up the unused CKF/VTEC/IAB leads, etc. That avoided the lengthening process you've started.
I suppose either can work, but the more wires you have to cut/extend/etc the greater the chance of error, or ground issues (etc). If you're careful it'll work fine too.
Mark
Old Apr 20, 2011 | 10:10 PM
first off thanks mark.
its a 98 ls. he got a 96 b18cR motor with the s80 lsd trans. it does not have vtec pressure sensor, ckf or evap. he has a p73 ecu that came with the engine. by legnthing i never cut any wires. just pulled the tubing stuff off and re routed wires and re taped on the engine harness. the chassis harness was pulled longer from under the dash and also re routed and re taped. we live in iowa and we dont believe in emissions here
did you also have to add wires for vtec? or just plug in the gsr haness and go? he was planning on using a gsr engine harness bit cant find any obd2a ones.
Old Apr 20, 2011 | 10:27 PM
If you use the ECU that came with it, you've solved the JDM .vs. USDM sensor issues!
As for wiring, I started with a GSR chassis, so the chassis harness had the VTEC wiring. In your case, you'll need to bring A8 (pin 8 of connector C408 at the ECM) out to the engine harness in order to enable the VTEC solenoid. At least, that's VTEC out in my GSR wiring doc.. C408 is the 32-pin grey connector on the ECM (big one).
I'd picked up a package somewhere that gave me pins for those connectors, but didn't need them - if your connector doesn't have anything in that spot you'll need to grab one somewhere.
Also, does your original engine have a knock sensor? The JDM one does, and it needs to find its way back to pin D6 (C410 pin 6). I think you'll really want that one.. the advanced timing will make it worth the trouble.
Good luck
Old Apr 20, 2011 | 10:52 PM
yes it had a knock sensor. im pretty sure all b18b motors had them. lol. since its a ls chassis im sure il have to wire the vtec in. since its only 1 wire im sure it will be relitavly easy. thanks for the tips hopefully this will all pulg in just fine
Old Apr 20, 2011 | 10:55 PM
It'll be great! (sorry Dad.. )
Have fun!
Old Apr 21, 2011 | 10:16 PM
11Bdc's Avatar
Good luck
Old Apr 23, 2011 | 01:04 AM
Motor is in. Wiring harness pluged right in. Gonna try to start it tomorrow. Fingers crossed.
Old Apr 23, 2011 | 03:01 AM
HondaPartsHero's Avatar
Technical Hero
You'll still have to wire up VTEC solenoid, VTEC pressure switch (if it has one), and knock sensor from the shock tower to the ECU as the LS isn't pinned for that. Most of the time its easier to reuse the harness that came in the car and add the wiring for the additional sensors. In case you need this:
Old Apr 23, 2011 | 10:14 PM
got00rice's Avatar
easiest thing to do is just get a usdm harness. when i bought mine itr from hmo, it was a plug and play with the jdm harness but wouldnt work. end up buying a 92-95 civic ex harness and a obd2-obd1 dizzy harness and everything start right up.
4cefed
Mar 21, 2013 07:11 AM
BOOSTEd2
13
Mar 28, 2011 04:56 PM
hannslebo
12
Jun 4, 2009 12:24 PM
01_ITR
Oct 6, 2008 05:42 AM
Mfoehrkolb
Aug 10, 2008 12:46 AM
