92-95 Airbag questions...
Old Sep 28, 2002 | 07:21 PM
BluCivicDriver93's Avatar
Default 92-95 Airbag questions...
Hey I'm new on here and I have a few questions for you. I deployed my dirver side airbag a while ago in a small mishap with a mailbox and i have a replacement airbag ready to put it but what do i have to do as far as the sensors and stuff? I think i have access to all the stuff i need because a friend of mine is parting out a 95 ex coupe.. that's where my airbag is from. Any info you can give me would be much appreciated. Thanks!
Old Sep 29, 2002 | 09:22 PM
AThiker's Avatar
Default Re: 92-95 Airbag questions... (BluCivicDriver93)
Bump for you
Old Oct 1, 2002 | 11:11 AM
bump
Old Oct 1, 2002 | 11:38 AM
jg's Avatar
jg
all of the srs system wiring is yellow. Pull the fuse, unplug under the steering column, and go from there. I believe it's all in the service manual. BE SURE TO DISCONNECT THE BATTERY BEFORE DOING ANYTHING! Let the car sit for 10mins. This lets any residual electrical current that may be in the wiring dissipate.
Old Oct 1, 2002 | 11:41 AM
bikeboy80's Avatar
Default Re: 92-95 Airbag questions... (jg)
if you have the access to a full srs system i would sugest swaping the whole thing in, there is a main computer right over the exaust hump against the fire wall, i have heard that they need to be replaced after an accident, and from there are two sensors in the driver an pasenger floorboards
Old Oct 1, 2002 | 11:43 AM
Okay, do i need all of the yellow (airbag) wiring? I already pulled the airbag oug i followed the manual and got it out with no problem. The two sensors, I believe, are under the dash on the firewall somewhere... do you know what tey look like? There is no wiring at all left in the car and I think the sensors are still in the wire but it would be helpful if i knew what they looked like. Thanks a lot.
Old Oct 1, 2002 | 11:52 AM
Default Re: 92-95 Airbag questions... (bikeboy80)
Btw, nice cars on the website! That was a tight Teg and it sucks that you crashed. The teg motor will be nice in the civic though! Good luck and thanks again!
Old Oct 1, 2002 | 11:56 AM
Yeah, a friend of mine is parting out a 95 ex... lucky for me and both airbags were undeployed and everything is there. I'm looking at about $300 for it. I know where the srs comp thing is, we pulled it the other day and like i said the wiring is all out so i just have to find it.
Old Oct 1, 2002 | 12:00 PM
bikeboy80's Avatar
thanks,
there are two metal covers that are over ends of the yellow wires in the floorboard (right where you put your feet, i dont remember what they look like exactly but when i go home tonight i'll take a look at them for you
Old Oct 1, 2002 | 12:10 PM
are they easy to see? the car is prett7y gutted so i dont know if they are still there or if theyre with the wiring. are they behind that sound damping **** or the firewall stuff?
Old Oct 1, 2002 | 12:19 PM
bikeboy80's Avatar
they might be behind the firewall padding, its been awhile since i had mine apart
Wdpfreak145
Jun 15, 2013 09:12 AM
PaperChasin
Aug 7, 2009 05:48 PM
nikpap55
Acura TL, RL & ZDX
Jul 5, 2008 10:37 AM
SkankWorksDA
Dec 17, 2003 10:58 AM
AThiker
Nov 26, 2003 02:37 PM
