Need Help with Solenoid
Old Sep 28, 2002 | 07:00 PM
Quick 200k Mile Motor's Avatar
Default Need Help with Solenoid
I'm only handicapped at Electronics
How would I test it when its off the car?
Its off of a GSR (I cant find out what year).
The Pressure Switch has 2 pins.
One pin is for the BLUE wire
The other pin is GROUND.
Which pin is for the BLUE wire?
Is it the nearest pin to the clip groove?
Please correct if Im wrong:
(+)Positive is the Solenoid pin.
(-)Negative is the pin other than the one for blue wire.
When testing it directly off a car battery, do I need to fuse it?
[Modified by Quick 200k Mile Motor, 11:03 PM 9/28/2002]
Old Sep 28, 2002 | 08:12 PM
Default Re: Need Help with Solenoid (Quick 200k Mile Motor)
btw, I did a search.
Nobody said anything about which wire goes to what..
Old Sep 28, 2002 | 08:47 PM
Ricky Rojales's Avatar
According the Helm's for a 95 GSR:
Blu/Blk (+) Top
Brn/Blk (-) Bottom
If you haven't already, please buy a Helm's maunual. Access to the internet may not be available to you when you need it most.
Old Sep 28, 2002 | 10:19 PM
miller's Avatar
Default Re: Need Help with Solenoid (P)
buy the book directly at your honda dealer.
Old Sep 29, 2002 | 08:26 AM
I posted this because I am missing the Male part of the harness.
Buy a book? I already have a helms. No book will tell you which color wire goes to the pin closest to the clip groove.
If you ever seen the pressure switch, its threaded in like all other sensors.
So indicating "Top" or "Bottom" wont make sense. Because the clip groove can be near the Top or off to the side.
All I need to know is: Which wire (color) is nearest to the clip on the Male harness? Oh, and..
Old Sep 29, 2002 | 01:21 PM
RenoRacing's Avatar
if you're refering to the oil pressure switch, it doesn't matter, trust me, i've done it both ways within the last week on my car and it worked, one just goes to the pin on the ecu and the other to a ground. to make sure the solenoid itself works just run power to the single wire to the solenoid and it should click and the shaft should move up and down
Old Sep 29, 2002 | 01:59 PM
AzG35's Avatar
Default Re: Need Help with Solenoid (HavokRacing)
I agree, it doesn't matter as long as one is grounded and one gets power. I've done it both ways as well.
Old Sep 29, 2002 | 07:13 PM
Default Re: Need Help with Solenoid (AzSi22)
you guys are awesome!
6KAOS6
26
Feb 19, 2011 07:22 PM
BOMBCRU
Apr 11, 2006 06:29 AM
