Fuel Setup for B20vtec
This is my set up
b20b4 block
RS Machines 84.5 itr style pistons
stock pr3-1 head from b16a3
stock cams
what injectors should i be running to be sufficient for this kind of compression?
would i have to change the fuel pump also?
b20b4 block
stock cams
Guys, im using b20 block with 85mm high comp piston. Skunk2 tuner 2 cams, pct cylinder head.
But i got a problem with my fuel setup.. My current setup is mitsubishi eterna turbo stock fuel pump and H22a injectors. But its still cant supply enough fuel.
What should i do?
What should i do?
You should start by creating your own thread.
Ditch the mitsu pump and do what was recommended for the OP. Not that hard man.
Red D Dragon
21
Mar 17, 2004 12:05 PM
boostincoupe
Mar 5, 2004 08:04 AM
