do i require a fuel pump with my setup?
Old Jul 11, 2004 | 07:39 AM
EARLdaSQUIRREL's Avatar
official honda whore
Default do i require a fuel pump with my setup?
i will have a greddy kit for my z6 put on within the next couple of weeks and i was wondering if i would need a fuel pump, i will be using dsm 450's with uberdata for fuel and management and one friend swears if i dont get a fuel pump i will end up blowing my engine running 10 lbs
so will i need an aftermarket fuel pump or no, and if i do, what would your recommendations be?
Old Jul 11, 2004 | 08:04 AM
kabaroo's Avatar
Default Re: do i require a fuel pump with my setup? (coptzer)
im wondering the same thing. same setup except ill be running hondata. i was told to use a 255 pump.
Old Jul 11, 2004 | 08:21 AM
snailpoweredEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coptzer &raquo;</TD></TR><TR><TD CLASS="quote">so will i need an aftermarket fuel pump or no, and if i do, what would your recommendations be?</TD></TR></TABLE>
better safe than sorry.
holley/walbro 255 LpH fuel pump.
Old Jul 11, 2004 | 08:22 AM
b16ahybrid's Avatar
Default Re: do i require a fuel pump with my setup? (kabaroo)
It's always nice cheap security, but from what I've heard (from reputable tuners) you should be fine using the stock pump with that set-up.
I've heard of the stock pump supporting 350whp although I wouldn't feel safe pushing it past about 250whp
Old Jul 11, 2004 | 10:45 AM
kabaroo's Avatar
Default Re: do i require a fuel pump with my setup? (b16ahybrid)
so with a stock fuel pump 190whp is fine? can someone tell me for sure!
Old Jul 12, 2004 | 12:35 AM
kabaroo's Avatar
up
Old Jul 13, 2004 | 09:31 AM
PA MATT's Avatar
i heard the rule is that 8 p.s.i. is the magic number and anything above this requires a fuel pump
Old Jul 13, 2004 | 10:04 AM
Mad Cow's Avatar
Default Re: do i require a fuel pump with my setup? (PA MATT)
There is no magic number, and nobody can tell you for sure... there are too many variables. Get the pump.
Old Jul 24, 2004 | 08:32 PM
its WANG yoO's Avatar
Default Re: do i require a fuel pump with my setup? (Mad Cow)
$90 i'd say buy it cheap ***!
Old Jul 25, 2004 | 03:58 AM
Honda_Tengoku's Avatar
yes I have also heard the stock fuel pump is good for 300 or so WHP. It should be fine with your stock one, but as everyone says 90 dollars for a walbro 255, why not take the cheap insurance. Not to mention its there for future upgrades. Might was well do it now. Injectors are the most effective way to increase flow to the engine, but u have already covered that I see. So if u want to slip out on it still, then u will be fine as long as your fuel pump is in proper working condition.
scspeed
Mar 26, 2009 07:20 PM
dturbo
Feb 27, 2005 10:32 PM
VspecSiR
May 17, 2004 04:37 AM
M.K.C.
Dec 15, 2003 08:01 PM
