type r cams in B16, need retainers?
Old Sep 28, 2002 | 06:25 PM
charjacq's Avatar
New User
Default type r cams in B16, need retainers?
I bought a set of type-R cams to put in a B16. I'm going to buy a set of type R valve springs. Do I also need retainers or will the stock B16 work ok?
Thanks for any info
Old Sep 28, 2002 | 07:56 PM
SC0TT's Avatar
Default Re: type r cams in B16, need retainers? (charjacq)
I would just to be on the safe side...if you dont plan to rev into the 9g range, the stock retainers should be alright.
Old Sep 28, 2002 | 11:55 PM
rice_classic's Avatar
Default Re: type r cams in B16, need retainers? (cr-tegra)
Why not? it's just as easy to find a complete ITR valvetrain.. springs, cams and retainers.. at least it was easy for me.
I did that to my b16 head and I safely shift at 9k.. Not that often though because I want my engine to last more than 20k miles
Old Sep 29, 2002 | 07:56 AM
charjacq's Avatar
New User
Default Re: type r cams in B16, need retainers? (rice_classic)
I got a set of type R cams from some guy with a ITR engine wanting to put GSR cams in (he's got a turbo and ITR cams have too much overlap), so I'll need to get a set of type-R springs from the dealer. My real question was, is there a difference between type R retainers and B16 stock retainers? Also, will stock B16 retainers fit with type R cams?
Thanks for any info
Old Sep 29, 2002 | 08:20 AM
SiR Kid's Avatar
New User
Yes, they will.
I've got ITR cams, ITR springs, and B16a retainers on my car now, and I rev it to 8500 all the time.
Old Sep 29, 2002 | 09:07 AM
STK B16's Avatar
Default Re: type r cams in B16, need retainers? (SiR Kid)
i would change it allat once.. that way you dont have to take the cams and springs apart a second time if you plan to put retainers .. plus its good to upgrade it as well. i would if i were you
crxaruba
15
Dec 7, 2020 11:46 AM
93egSLEEPER
11
Dec 22, 2009 12:28 AM
Weel
Feb 9, 2008 06:07 PM
TreeToTall
Apr 19, 2006 06:33 PM
