how to remove eagle rod bolts
Old Sep 28, 2002 | 06:18 PM
vtec69's Avatar
Default how to remove eagle rod bolts
ok, i had the machine shop put on the piston rings and eagle rods together. now i've come to a problem. the bolts the hold the rods together are some weird looking nuts. i wanted to know if anyone knows exactly what tool i need to remove the bolts so i can put them in the crank. here is a picture so you can see what i mean.
Old Sep 28, 2002 | 06:20 PM
Quaalude's Avatar
Default Re: how to remove eagle rod bolts (vtec69)
it looks like you would only need a 12 or 14 mm-12 pt. socket
Old Sep 28, 2002 | 06:27 PM
Flamenco-T's Avatar
Default Re: how to remove eagle rod bolts (Quaalude)
10mm 12 pt socket
Old Sep 28, 2002 | 08:10 PM
GruvyTune's Avatar
New User
Default Re: how to remove eagle rod bolts (Flamenco-NA)
and a vice with some soft rubber surrounds.
SanadaSand207
May 29, 2018 05:54 AM
Canadian_EF
Oct 9, 2013 03:36 PM
BlueSi2k
Apr 23, 2003 10:50 AM
vtec69
Sep 29, 2002 04:39 PM
vtec69
Sep 28, 2002 07:27 PM
