What ecu do i need? 92 dA Plz help..
Old Apr 19, 2011 | 04:50 PM
B20zCrx's Avatar
Default What ecu do i need? 92 dA Plz help..
I have a 92 integra gs its auto and i just converted it to a standerd and put a gsr head on the factory block. Idk what ecu to go with?
Old Apr 19, 2011 | 08:08 PM
HAMOTORSPORTS's Avatar
Default Re: What ecu do i need? 92 dA Plz help..
Your best bet if you are using a stock GSR intake manifold on your GSR head is a 94-95 P72 GSR ECU. It will plug-n-play into your 92 integra harness, just wire VTEC, Vtec oil pressure, knock (you will need to find a way to mount a knock sensor), and IAB.
Another option (better) is to run a chipped P72 with knock disabled so you don't have to try to mount the knock sensor or worry about erroneous readings retarding timing.
Old Apr 20, 2011 | 06:30 PM
B20zCrx's Avatar
Really... Well the b18bs come with the nock sensor on the back the blok were on a b18a1 its just a blockoff plug. I have a b18b block with it so i can just put it on my block and itl all be fine? Correct? Thx for the help btw.. Andd i guess i need a p72.. Soo with that nein said does anyone have one forsale? Lol
Old Apr 22, 2011 | 07:37 AM
B18B's do NOT have a knock sensor on the block. You will need to find another way to mount one if you go that route.
Old Apr 22, 2011 | 12:49 PM
eaperez209's Avatar
real simple use a chipped p28 and all you do is wire up ur vtec selenoid....
Old Apr 22, 2011 | 01:13 PM
eaperez209's Avatar
or a chipped p72 would work nicely too harder to find tho
Old Apr 22, 2011 | 06:41 PM
Not that hard
http://www.hamotorsports.com/socketedp72.html
Old Apr 23, 2011 | 08:46 AM
eaperez209's Avatar
lol very nice....matt ryte? you guys still getting good deals on mounts? 92 gsr with hydro trans billet w/ red inserts?
hondaman1212
May 8, 2008 08:59 PM
Elevorett
Feb 14, 2007 05:35 PM
xtreme-customz
Jan 6, 2006 05:09 PM
jack25racing
Jun 6, 2002 10:59 AM
X2BOARD
May 30, 2002 05:41 AM
