Transmission & Drivetrain Gearboxes, Differentials, Clutches
Ways to identify if your trans is a b16 or gsr
Old Apr 19, 2011 | 10:16 AM
Antilag's Avatar
Default Ways to identify if your trans is a b16 or gsr
Bense, if you would like to add this to your trans topic, it would be great.
Thanks to David from synchrotech the genius of trannies. Heres info that can really help.
I have alot of customers ask, i need a lsd but cant tell if its a b16/ls or gsr cause the sticker is ripped off.
3 ways to confirm.
#1 your ring gear. The big hole where the diff fits into. The measurements are close but different. B16 is 116.8 mm and the gsr will measure 119.8. edge to edge
#2 your ring gear face. along the oem ring gear face they both have id lines that run around on the teeth. If it has 2 id lines one top and one bottom its a B16, if it has 1 id line in the middle its a gsr.
#3 stock oem 3rd gear on the main shaft, count the teeth and double count cause they are only 1 off to differentiate the 2. If you count 24 teeth on the main shaft 3rd gear its a B16, if you have 25 teeth than its a gsr.
Hope this helps everyone.
Old Apr 21, 2011 | 03:54 PM
05foresterxt's Avatar
Default Re: Ways to identify if your trans is a b16 or gsr
Great info
Old Apr 22, 2011 | 08:01 AM
David @ Synchrotech's Avatar
The LS FD also has 2 ID lines on the R/G with a 109.8mm hole but with a 64 tooth ring gear.
B series transmissions 1994-2001
LS: 64T (tooth) R/G 2 lines (109.8mm), 15T C/S 2 lines, 26T M/S 3rd 2 lines.
GSR: 66T R/G 1 line (116.8mm), 15T C/S 3 lines, 25T M/S 3rd 1 line.
B16 66T R/G 2 lines (109.8mm), 15T C/S 3 lines, 24T M/S 3rd no line.
Old Apr 22, 2011 | 08:12 PM
sh!ft's Avatar
Who the fack changed my title?!
here ya go dave LOL
http://www.ff-squad.com/tech/temp/Bgears.htm
Old Apr 28, 2011 | 06:44 AM
MR.johnson's Avatar
good info. i should go threw some of my junk and figure out what i really have laying around.
Old Mar 13, 2017 | 09:55 PM
Toro452's Avatar
Default Isthis Gsr? Or.b16?
This GSR or B16?
Old Mar 15, 2017 | 06:46 AM
It is a GSR (116.8 mm diameter hole and 1 ID mark in middle of tooth)
Old Mar 23, 2017 | 03:27 AM
0c00l's Avatar
Great info, this should be stickied
Tkthedk
Oct 14, 2011 02:06 PM
ashb82
Aug 15, 2011 02:28 PM
sj-performance
Nov 9, 2009 02:35 PM
96 GSR-T
Dec 24, 2007 10:26 AM
DaveF
Sep 22, 2003 08:53 PM
