Transmission & Drivetrain Gearboxes, Differentials, Clutches
3rd gear question.
Old Apr 19, 2011 | 10:05 AM
CA121's Avatar
Default 3rd gear question.
hi, anyone know if the 3rd gear is interchangable on h series boxes?
i'm looking to use my long 2nd gear and put a short 3rd gear in from a different box.
many thanks Adam
Old Apr 19, 2011 | 10:06 AM
TaffetaEj6's Avatar
Default Re: 3rd gear question.
yep sure are
i believe h and f are interchangable as well?
Old Apr 19, 2011 | 01:21 PM
CA121's Avatar
cheers mate
Old Apr 19, 2011 | 04:04 PM
David @ Synchrotech's Avatar
many thanks Adam
You can use a match set of H22 gears (C/S & M/S) on any H22 box or a match set from an H23 in an F22. The synchro size is different from the H23/F22 and H22 so in order to swap these you will need to change both 3rd gears, both 4th gears along with the 3-4 sleeve, hub, synchros, springs and forks..
Old Apr 19, 2011 | 08:00 PM
TaffetaEj6's Avatar
damn...you are the perfect person to chime in on this thread
Old Apr 22, 2011 | 08:26 PM
sh!ft's Avatar
Who the fack changed my title?!
just like a b series lol
Old Apr 24, 2011 | 01:14 PM
JULIAN TYPE R's Avatar
I want 1st 2nd 3rd. B16 and.4th and 5th LS ...is that possible??
Old Apr 24, 2011 | 02:02 PM
No - the LS 4th is smaller and uses a smaller synchro. Since 3rd and 4th share the same fork and sleeve, this set up will not work. You can do the B16 1-3, GSR 4th and LS 5th.
Old May 17, 2011 | 10:54 AM
CA121's Avatar
my ideal situation would be a long 2nd gear from the m2j4 2.0 4th gen prelude box with the short 3rd gear from u2q7 accord type r box
what would i need to do this, the only other gear needed would be reverse,
1st 4th and 5th are not needed.
many thanks Adam
Old May 17, 2011 | 11:12 AM
sh!ft's Avatar
many thanks Adam
both counter and main shaft gears would be needed along with the sliding hub assembly and synchro/spring. id grab both boxes just to make sure you do not need to swap shafts /other gears just to be safe
Contender_h22a
Oct 15, 2010 06:59 AM
pkolaboy
Mar 26, 2008 02:27 PM
h22_crx
Jan 25, 2007 03:25 PM
NirVTEC
May 1, 2005 11:12 PM
