6 gen ex rear disk/ MC questions
Old Sep 28, 2002 | 05:26 PM
s73's Avatar
s73
New User
Default 6 gen ex rear disk/ MC questions
any of u guys have a 6 gen civic ex swap to rear disks?
i got a set of del sol rear disks, i am just wondering if my 7/8 civic ex MC is ok?
somepeople told me that my stock prop valve is ok, some say its not ok, some have even stated that the si mc is the same as the ex...(i know it sounds weird, ex got drums in the back, si got disks)
what size is the 99 si mc? 7/8 or 15/16 (i know that the tags got a 15/16 MC)
please let me know if u guys got any info on this, or if you guys did this brake swap on a 6 gen ex w/o changing the mc/ bb/ PV
thanks
Old Sep 28, 2002 | 06:07 PM
DragII's Avatar
25 Year Member
Default Re: 6 gen ex rear disk/ MC questions (s73)
I used my stock MC on my 96 ex coupe, it worked just fine w/ gsr rear disks.
[Modified by ^..^, 10:07 PM 9/28/2002]
Old Sep 28, 2002 | 06:09 PM
FifthGearOnline's Avatar
Default Re: 6 gen ex rear disk/ MC questions (^..^)
si's have 15/16
s73's Avatar
s73
New User
did u swap out the prop. valve? or you just used your stock ones?
btw what is the size of your MC 7/8?
Old Sep 28, 2002 | 06:17 PM
6ghatch's Avatar
The SI M/C is the same with maybe a larger reservoir as to hold more brake fluid, but yours will be fine. If you really want to upgrade do the ITR M/C and brake booster swap. It really cuts down on the amount of pedal travel and just bolts right into 6th gen cars. The brake lines match up perfectly!
[Modified by 6ghatch, 10:23 PM 9/28/2002]
Old Sep 28, 2002 | 06:18 PM
s73's Avatar
s73
New User
Default Re: 6 gen ex rear disk/ MC questions (FifthGearOnline.com)
i just did a parts search for the two MC, the OE honda part number for the 99+ si and the ex are the same!!! at lease the years that i searched (97-00) if its the same part number, it must be the same part, and i just went outside to look at my and my friend's civic ex and my civic ex (my is a 97 his is a 00) and both our MC are 7/8
i think only the 5 gen si's (3 door HB) have 15/16 mc (i may be wrong)
i am pretty sure now that the 99+ si's have 7/8 mc (i may be wrong)
Old Sep 28, 2002 | 06:39 PM
DragII's Avatar
25 Year Member
stock prop valve too.
Old Sep 28, 2002 | 07:25 PM
YumVTEC's Avatar
any value in using a 99-00 Si Prop valve on my hatch with 5-lug conversion and ITR MC?
Old Sep 29, 2002 | 08:36 AM
6ghatch's Avatar
Default Re: 6 gen ex rear disk/ MC questions (YumVTEC)
No, they are the same part for the 99-00 SI and all other 6th gen Civic's.
Old Sep 29, 2002 | 02:53 PM
YumVTEC's Avatar
Default Re: 6 gen ex rear disk/ MC questions (6ghatch)
Hrm... that doesn't make logical sense to me, that the prop valve on a car with discs/drums is the same as on a car with all discs. I'll have to call Honda to verify, but if you're right, then I'm boggled...
Old Sep 29, 2002 | 03:14 PM
6ghatch's Avatar
It's because Honda's don't have front to rear bias porp valves. They just separate FL to RR and FR to RL for safety reasons.
Old Sep 30, 2002 | 04:38 PM
DragII's Avatar
25 Year Member
IMO rear disks do not take anymore pressure to make them work...so I just don't, and didn't see the necessity of upgrading...if the MC has enough pressure to adaquately push the front disks there shouldn't be a differance for the rear. since one front, and one rear wheel is on each system. the pressure should be equal for front and rear.
Old Sep 30, 2002 | 06:06 PM
6ghatch's Avatar
You are correct, the front to rear brake bias is based on caliper and rotor size.
ej14life
Nov 26, 2009 04:33 PM
chinochanginc
Dec 31, 2007 01:59 AM
malubawla
Apr 5, 2006 03:05 AM
NW94RS
Jan 15, 2004 11:05 PM
s73
Sep 29, 2002 12:08 AM
