help asap 99 crv 5spd 4wd
so my crv one day just stopped running with no cel or anything, i checked timing belt, spark, fuel and timing... all were good. i can get the motor to start and idle after cranking on it for a little bit, it will aslo rev up if you go slow but will stall if you press the gas fast but the motor will not take any load.
any help will be appreciated
Could be the coil which is inside the distributor.
Could be the MAP sensor which advances the ignition timing when you apply load.
Quickest way to check these is to swap them out with known good units.
jpnolan
Jun 10, 2013 04:29 PM
AllMotorHB
39
Sep 24, 2010 12:41 PM
danwants2btheman
Jun 3, 2007 11:45 AM
