Transmission & Drivetrain Gearboxes, Differentials, Clutches
obx lsd
Old Apr 17, 2011 | 11:32 PM
hatche1's Avatar
Default obx lsd
well i wanted to know if anyone knows how good the obx lsds hold up? i want to get one for my hatch but don't know how good it is. i am looking to put down anywhere from 300whp to 450 whp on my single.
Old Apr 18, 2011 | 01:07 PM
hatche1's Avatar
Default Re: obx lsd
Anyone???
Old Apr 18, 2011 | 03:16 PM
Gearspeed-Performance's Avatar
Default Re: obx lsd
Been covered many times on here and highly debatable. In my opinion..they are poor quality and will never have a place in our shop. Majority of them are not assembled correctly from the factory, the quality is nothing close to good, and the specs are off! Would rather spend more money and go for a more Quality unit like an M-Factory, Quaife or Wavetrac...depeding on your budget.
Old Apr 18, 2011 | 09:19 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: obx lsd
Before OBX's QC went to crap, I installed 40+ without issues.
For the past 2-3 years I'll only touch MFactory or Quaife with a preference towards MFactory. I've installed three of them so far and NONE of them required ANY shimming. Honda calls for .000-.004" clearance, I prefer .004-.008" in performance applications, all three MFactory LSD have fallen in .005-.006" with new bearings.
You still MUST check EVERY install, every time.
Old Apr 19, 2011 | 06:19 AM
David @ Synchrotech's Avatar
Default Re: obx lsd
We do not install or sell OBX LSD's in our transmissions but we have removed several that have failed. For a helical LSD, Quaife, Wavetrac, and MFactory have the best quality. Over the past few years we have used the MFactory LSD and have never had a problem.
Old Apr 19, 2011 | 08:32 AM
hatche1's Avatar
Default Re: obx lsd
so i'm guess mfactory is the way to go.
Old Apr 19, 2011 | 08:36 AM
hatche1's Avatar
Default Re: obx lsd
also would changing my final gear help aswell?
Old Apr 19, 2011 | 08:03 PM
Aquafina's Avatar
Default Re: obx lsd
I do not sell or install OBX's anymore either. I accepted one earlier this month to install so I could see first hand if any issues were corrected. None were and it had too much runout as well as being improperly assembled.
Yes, changing your final drive will help greatly with acceleration (see the link to my thread in the sticky).
Old Apr 20, 2011 | 07:47 AM
MR.johnson's Avatar
Default Re: obx lsd
i bought one to try, 2 years at 500+ whp still holding up. but has shown some wear when i check out the trans...
Old Apr 20, 2011 | 11:11 PM
hatche1's Avatar
Default Re: obx lsd
do you know what would be a great final gear to go with? brand wise and size of gear?
Old Apr 20, 2011 | 11:28 PM
Aquafina's Avatar
Default Re: obx lsd
MFactory. Ratio depends on your power, tire size, and rev limit.
Old Jan 1, 2013 | 08:58 PM
Myroslav69's Avatar
Default Re: obx lsd
OBX LSD is terrible! You might as well leave your oem differential in. I had 2 OBX LSD's in my turbo GSR, both failed miserably!!! They seem to work at first, but then they just fall apart. I'm getting MFactory now.
Old Jan 2, 2013 | 04:45 AM
MR.johnson's Avatar
Default Re: obx lsd
from the dead!!
mine blew up lol.
Old May 2, 2016 | 03:41 PM
Drzhope89's Avatar
Default Re: obx lsd
I called Obx Racing Sports and talked to some guy named (PETER) and i was having issues that my passinger side axel was getting stuck theres OBX axle KIT for sale and i asked him will i have no problem putting the these axles in the tranny he told me no (600$) for the kit I wana know whats gonna happen if i really order this kit and if it fits then theres the problem i know i did the measurement on the Differentional it is off by .001MM on the passinger side so if your trying to stick the passinger side axle in you have to take it to a driveshaft shop and tell them to shave off .001MM off the passinger axle to make it fit smooth
Obx Racing Sports
Phone: (510) 568-2244
Old May 2, 2016 | 07:26 PM
king06's Avatar
Default Re: obx lsd
I'm pretty sure buying those shitty axles isn't going to fix the problem. So don't waste your money.
Look at this
De-mystifying and Bulletproofing the OBX LSD (Re-born) - Club RSX Message Board
Old May 4, 2016 | 06:28 AM
Aquafina's Avatar
Default Re: obx lsd
They cannot make a differential with proper clearances, why would you risk even more of your money on axles from them? Chalk up the loss and switch to a quality LSD.
1998GsRIntegra
14
Sep 8, 2011 02:09 PM
NonovUrbizniz
Jan 20, 2009 01:01 PM
infumis
Jan 17, 2007 01:17 PM
GO-FIGHT-KILL
Oct 8, 2005 08:25 PM
johnjw
Mar 17, 2004 01:13 PM
