Transmission & Drivetrain Gearboxes, Differentials, Clutches
Syncromesh
Old Apr 17, 2011 | 04:15 PM
Slacker93eg's Avatar
10 Year Member
Default Syncromesh
Okay so I just got my eg a few days ago and I want to flush out the trans fluid. I've heard syncromesh somewhere before, and now I search here and I only find a few posts and people are kind of 50/50 on using it. What are your opinions on it, if you suggest against it, why and what would you recommend?
Old Apr 17, 2011 | 04:56 PM
Honda Bull's Avatar
Default Re: Syncromesh
Amsoil MTF
GM Synchromesh FM
Honda MTF
Motul Motylgear
Pennzoil Synchromesh
Redline MTL
Torco MTF
Pick one, try it, and see how you like it. If you don't, move on to another. If your transmission is in good shape and doesn't get abused, you'll see very little difference between the fluids for all intents and purposes. It's more important to change the fluid regularly and service bearings/synchros as they need replaced, IMO.
But yes... I use Pennzoil Synchromesh in my personal DD - 370 whp, 11.3-second stock-block GSR setup. I've run Honda MTF, Amsoil MTF, and Motul Motylgear, as well. The Pennzoil Synchromesh has been the best bang for the buck given how often I change it, and is incredibly easy to find.
Old Apr 17, 2011 | 05:24 PM
10 Year Member
Very nice! I'll give that a try, and service intervals are my thing man, I'm a manager at a lube place for now. I get that **** next to nothing, oil is changed every 1500-2000 miles lol. I'm definitely more of a "maintain rather than replace" kind of guy. So you like pennzoil huh, How'd you like the Amsoil?
Old Apr 18, 2011 | 09:13 PM
Mista Bone's Avatar
D Tranny Guru
no Redline MTL or MT-90.....or current Honda MTF.
Most of my OBX were using Synchromesh without issues, I've never heard back from them, which is a GOOD thing!!!!
Old Apr 19, 2011 | 06:40 AM
10 Year Member
Are you saying don't use those, or use those? lol
Old Apr 20, 2011 | 07:46 PM
*EFilliated*'s Avatar
i would also like to know what people use on decently fast cars
Old Apr 21, 2011 | 09:07 AM
Gearspeed-Performance's Avatar
Torco RTF in race applications, and Torco MTF or Honda MTF in DD.
Old Apr 21, 2011 | 08:05 PM
may i ask what is special about Torco RTF and where can it be found
Old Apr 22, 2011 | 07:17 AM
David @ Synchrotech's Avatar
We have Torco MTF and RTF - PM me for prices. Here is some info on the Torco transmission oils:
Torco MTF (Manual Transmission Fluid) is a API GL4 light viscosity oil and is highly recommended for high performance street applications in Honda transmissions.
Torco RTF (Racing Transmission Fluid) is 100% synthetic rated API GL6. It provides superior shear resistance and extreme temperature stability. RTF is specially formulated to exceed the load-carrying and extreme pressure wear properties of higher viscosity gear oils.
Old Apr 22, 2011 | 02:11 PM
05foresterxt's Avatar
I've used GM Synchromesh and did feel a difference in shifting compared to Honda MTF. Seems as Honda MTF is a thinner oil compared to the GM Synchromesh.
Old Apr 22, 2011 | 04:26 PM
10 Year Member
The computer at work says the MT fluid type is SAE 10w30. O.o
I think I'm gona try syncromesh first
Old May 26, 2011 | 07:34 PM
dezyred_temperz's Avatar
im actually thinkin about trying the redline mtl. its a bit pricey but ive always used honda mtf. just wanted to try something different to see. anyone have any problems with the redline mtl??
Old May 27, 2011 | 11:15 PM
Mista Bone's Avatar
D Tranny Guru
yeah, it ruins bearing cages.
Stick with 10w30 or Synchromesh.
fivespeedintegra
Honda S2000
74
May 29, 2011 07:02 PM
esoterEK..
Honda S2000
Feb 13, 2010 07:41 AM
L-Dawg
Honda Civic (2006 - 2015)
40
Apr 9, 2007 07:51 AM
Lude S
Jun 11, 2005 02:10 AM
95GS-R
Sep 14, 2002 04:48 PM
