Ostrich2.0 Paint Project - First Time!!!
Old Apr 17, 2011 | 12:39 PM
Ostrich2.0's Avatar
Default Ostrich2.0 Paint Project - First Time!!!
I am going to chronicle my paint project from first to start. Bought the car about a year ago and she was a 10 footer. Lots of deep scratches, a few dings, and a tad bit of surface rust.
Currently she is Electron Blue Pearl, I am going to paint her Viper Blue so i dont have to repaint the door jams and engine bay.
Going to be painting the wheel Black Firemist.
I ordered all my paint from Tcp Global for 350 shipped.
Here is a few pics of my first hour...to humid today to do much more.
Old Apr 17, 2011 | 01:54 PM
Ostrich2.0's Avatar
Default Re: Ostrich2.0 Paint Project - First Time!!!
Heres the spray gun set i ordered
http://www.tcpglobal.com/spraygundepot/tcpgate.aspx
Heres the paint. Its a single stage Acrylic Enamel. I plan on spraying 2 coats of clear after it cures
http://www.tcpglobal.com/restorationshop/rsp2508.aspx
Primer. Its a white epoxy primer.
http://www.tcpglobal.com/restoration...pepoprime.aspx
Old Apr 17, 2011 | 03:40 PM
shocker911's Avatar
are you taking it down to bare metal?? hard to tell in the pic. you really only need to scuff the paint unless the paint job is crap that you are going over
Old Apr 17, 2011 | 06:14 PM
OldSchool Honda's Avatar
What are the differences between the two colours?
Old Apr 17, 2011 | 06:15 PM
Ostrich2.0's Avatar
paint job was crap. Looks like rattle can primer underneath the paint.
im not taking it down to bare metal though.
I used an orbital sander with 220 grit, then i plan on using a sanding block with 320 grit to finish it off before i spray the primer.
Old Apr 17, 2011 | 06:17 PM
Ostrich2.0's Avatar
Just ordered an antennae block off plate. I dont even listen to the radio but i plan on stealth mounting one when i replace the old cd player.
the last owner didnt hook up the antennae for some reason...
Old Apr 17, 2011 | 06:30 PM
Ostrich2.0's Avatar
Not a whole lot. The viper blue is a bit deeper blue, same color as the dodge viper, hence the name.
The electron blue pearl is a bit on the purple side. Im sticking with a similar color so i dont have to redo the door jams and engine bay.
Not a fan of the purple hue in my current paint...
Old Apr 18, 2011 | 12:45 PM
Ostrich2.0's Avatar
Guns and paint came in today. Comes with stirrers and strainers.
Old Apr 18, 2011 | 12:46 PM
Ostrich2.0's Avatar
got a little bit more sanding done this morning before work. Sanding a car in a apartment complex is apparently frowned upon, who knew?
Old Apr 18, 2011 | 03:28 PM
egp95's Avatar
Tell me how the spray gun will work out for you. I will be repainting my engine bay and then possibly the whole car. So I will need to pick up a spray gun soon.
Keep us posted, looking forward to seeing this car being fresh.
Old Apr 18, 2011 | 03:36 PM
Ostrich2.0's Avatar
The only thing i dont like about the set so far is the adjustable pressure regulator. The nut the hooks it onto the gun seems a little loose for my liking.
Other than that, its a good set for the money as long as it sprays ok. $80 for three guns, primer gun, basecoat/clear gun, touch up gun, and cleaning kit.
Im gonna spray some old paint next week to get a feel for the settings n stuff.
Old Apr 18, 2011 | 03:37 PM
Ostrich2.0's Avatar
Ordered a type R lip for the front. Contemplating painting this black firemist like the wheels...
Old Apr 18, 2011 | 04:33 PM
atleast-3's Avatar
paint it the same color as the car
Old Apr 18, 2011 | 05:08 PM
Cain Marko's Avatar
Rotary Lift Specialist
make sure before you spray on the clear after the single stage has cured, that you wetsand with a 1500-2000 grit paper or else the clear wont adhere to the paint you have layed on already, if you wanted to go that route, why not base/clear?
Old Apr 18, 2011 | 06:04 PM
Ostrich2.0's Avatar
Stupid mistake actually. I didnt mean to order single stage and i wasnt interested in spending another 60 in shipping fees both ways,
They told me to wait 2 days before i spray the clear.
Old Apr 19, 2011 | 06:07 PM
Ostrictch, do you have any spray gun painting experience?
I was thinking of getting something similar, and was wondering how you're fiurst experience will be.
Old Apr 19, 2011 | 10:00 PM
eg_wookie's Avatar
cool glad your doing a write up cause im getting paint for tcp global for my car, actually went today pricing stuff to build a ghetto paint booth in my yard
Old Apr 20, 2011 | 05:57 AM
Ostrich2.0's Avatar
they are really helpful.
I just sent my single stage back to them to switch for a better bc/cc system. They waived the restocking fee for me!
Single stage would have been a bitch to try and clearcoat and since its a metallic you could ruin it trying to sand it.
Old Apr 20, 2011 | 07:33 AM
Ostrich2.0's Avatar
only one experience. I tried to spray acrylic lacquer on my 75 F100 last year in 15 mph winds with an ebay siphon feed gun that literally fell apart in pieces while spraying.
So no, not much.
Im using my father in laws garage and plastic sheeting the entire thing, Were starting to clean it out tomorrow to get all the dust out and rigging a filtration system.
Im planning on doing a trial run with the primer on the front lip and sideskirts to make sure all the settings are down.
The spray gun kit came with an adjustable pressure regulator, so hopefully that will help me dial in everything accurately. The TCP global paint came with tech sheets that list all the settings for each type of paint/primer.
Old Apr 20, 2011 | 03:02 PM
dezwilliamz's Avatar
Looking forward to seeing the final result. I painted my car back in 04' and the paint is fading on me due to the Florida sun :/. I did a house of kolor pearl blue. Looked killer for sure. The viper blue is similar so it should look nice!
Old Apr 20, 2011 | 03:35 PM
Ostrich2.0's Avatar
any pics?
House of kolor paint is expensive!!!
Old Apr 20, 2011 | 03:40 PM
Ostrich2.0's Avatar
Finish sanding the hood 220 grit today.
Im off work tomorrow, so hopefully i can get the whole car done in the 220.
Next week i will hopefully get to wetsand the car down with 320.
The 3M sanding block i got from TCP Global is killer. Keeps a nice flat sanded surface to avoid high and low spots.
I will update with some pics tomorrow...also ordered some more clearcoat. Hoping to do at least 6 or 7 cuts so when i cut and buff, i wont burn through the clear
I totally tried to use paint stripper on the door handles, FAIL. made the paint all bubbly and hard to sand off. Should have used my dremel for the nooks and crannies.
Old Apr 21, 2011 | 03:10 PM
Ostrich2.0's Avatar
got a little bit more sanding done today
Old Apr 21, 2011 | 03:11 PM
Ostrich2.0's Avatar
My bumper has a 6 inch hairline crack in it.
Im using this Upol stronghold plastic filler, gonna open it up a little bit with the dremel and then start patching from the back of the bumper
Old Apr 22, 2011 | 05:55 AM
Ostrich2.0's Avatar
finished sanding the passenger side of the car.
All i have left now is the front bumper and rear trunklid, wing, rear bumper.
I am going to remove the mirrors as well and give them a good once.
Picking up some JB Weld as well, Im going to adhere some pennies in the holes on the trunk lid and hood where the emblems were. Fill them up with bondo and sand. Hopefully it will look a bit sleeker without the holes, plus it wont leak in my trunk anymore! YAY!
