B16a code 15
Old Apr 16, 2011 | 04:23 PM
xero_xero's Avatar
Default B16a code 15
87 Si Rex (know this isnt the forum for the body) with a complete wiring transplant from a 91.
Zdyne 91 si ECu
B16a oem all the way around
gsr cable trans
hasport axles and mounts for b series to 1st gen crx.
NEW CONNECTORS AND PINS ALLL THE WAY AROUND from iether zdyne or hasport.
Code 15, checking grounds. no spark, plenty of fuel. . can providde pics of everything as of tomorrow.
this is a transplant from another car, identincal civic of the same body style. the civic drove for 6 moths, was wrecked and then the car sat for 5 years. checking ecu wiring today.
Old Apr 16, 2011 | 04:49 PM
gringo7718's Avatar
Default Re: B16a code 15
Please give more info regarding how long the swap has been in the car.
There is a big difference between:
a. The car ran fine for a few months, then died, and now no spark.
b. Just completed swap and No Start/Spark
Did it ever run?
For how long?
What symptoms did the car have before it got to this point?
Did you change anything?
Have you done a tune-up or replaced Distributor?
Old Apr 16, 2011 | 05:01 PM
xero_xero's Avatar
sat for 5 years, new dizzy, ran in comparable civic for 6 months with no problem. Hasport did the harness as well. everything looks mint. ohmed out all wires and everything has continuity from inside the dizzy to its corresponding end points.
holds 195 on ch cylinder, has fuel, no spark at the dizzy. new coil, new icm, original tdc and crank positiion. can post pics if necessary to answer any questions of wiring.
Old Apr 17, 2011 | 05:02 AM
xero_xero's Avatar
will post pics shortly
Old Apr 17, 2011 | 05:34 AM
gringo7718's Avatar
New car, new wiring, engine hasn't run in 5 yrs.
It seems like you are on the right track checking all of the wiring. Good luck
Test another ignitor module - Test the Blk/Ylw wire from the 2 pin round connector on the distributor. With the ignition switch on, there should be battery voltage. If not, the wire is shorted somewhere. If there is voltage and the car still doesn't start, check to the two white wires coming from the distributor. You'll need to test them at the ecu. You'll again need to test for voltage. Test terminal B15(+) and B17(+) against A18(-), you should have +/- 10v. If not, it's the ignitor.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/replacing-ignition-control-module-igniter-2581960/
Test another ECU - What ECU are you running ?
91 crx Si ECU is the wrong ECU for a B16 (Zdyne or not). You should be using PR3 or PW0 if you are still obd-0.
Old Apr 17, 2011 | 06:59 AM
xero_xero's Avatar
that's what im looking for. tested another ignitor out of a d15b8.
pics up with descriptions.
Car
New Pints, no corrosion
Drivers side plug with fix
cut wire but leads to the core support
ECU zdyne unkown condition, oem ecu - toast
Old Apr 18, 2011 | 05:01 AM
gringo7718's Avatar
You need to get the correct ECU for your engine. And also your wiring looks like hell, so fix that too.
Old Apr 18, 2011 | 04:42 PM
xero_xero's Avatar
ecu doesnt matter(dpfi for dpfi or mpfi for mpfi), ecu was fine, bad ignitor, and as far as my wiring, i dont see anyone else forking over 300 for a pin kit and they were spread a part to get a better view, but thanks for trashing my rex and offering a solution to my problem all in the same thread....
Old May 19, 2014 | 04:24 PM
Lil SyKe's Avatar
ok. Now i got the same problem. did a full swap with wiring harness, engine, trans b16a into an 88 crx. I checked all my grounds and voltage, I got 9 volts going to both igniter ins at the ECU and i checked along each connector and its continuous 9 voltes. still no start and code 15. I have a PW0 ecu and checked the pinouts. pr3 and pw0 are both the same from what i can find. but still code 15. any ideas? I just ran my own wires straight from the engine harness connector from the igniter straight to the ECU. check the wire diagrams and it seems that they ran straight there, so i just got rid of like 8 feet of wiring and ran it straight and still the same code.
Bagged_em1
Oct 31, 2016 06:09 PM
zlambe
Sep 7, 2008 10:36 PM
I8ayellowcrayon
22
Jul 14, 2008 05:48 PM
phatstyles
15
May 23, 2005 05:17 PM
importboi22
11
Jun 22, 2004 01:10 PM
