F20B ECU tuning.... any other things need to change
Old Apr 15, 2011 | 12:40 AM
jackiewong518@h's Avatar
Default F20B ECU tuning.... any other things need to change
I own a JDM Accord CF4 Sirt running with F20B DOHC engine(should be OBD2B)....recently, I'm buying the stuff for ECU tuning as below
1) EuroR Intake manifold
2) IACV adapter plate with 2 wire IACV to change the existing 3 wire IACV to 3 wire...
3) P28 chipped ECU with basemap
4) ECU Jumper Hardness (OBD2B to OBD1)
Any other things I need to buy for the ECU tuning? or any other things i need to take note on?!
Hope someone can help me....
Old Apr 15, 2011 | 09:50 AM
GhostAccord's Avatar
Default Re: F20B ECU tuning.... any other things need to change
Hello again Jackie, small world eh!
If you are going to be doing the tuning yourself you will need a laptop, tuning software with dataloging capabilities (eCtune Demon, Neptune Demon or Crome Pro w/Moates Ostrich) a dataloging cable (Moates hulog) and a wideband O2 sensor w/controller (Innovate makes some good Wideband tuning products).
Good luck
Old Apr 15, 2011 | 09:19 PM
If you are going to be doing the tuning yourself you will need a laptop, tuning software with dataloging capabilities (eCtune Damon, Neptune Damon or Crome Pro w/Moates Ostrich) a dataloging cable (Moates hulog) and a wideband O2 sensor w/controller (Innovate makes some good Wideband tuning products).
Good luck
Yup...i want to have the tuning myself & thanks for the suggestion....
Before that, I want to confirm all my stuff preparation is ready on the engine-room....so that i can test with the chipped ECU.....
Old Apr 22, 2011 | 03:55 AM
anyone can help?
Cr1424
Engine Management and Tuning
10
Mar 7, 2014 09:49 AM
Will Albers
Mar 12, 2009 11:20 AM
drintegra
Jan 10, 2007 01:15 PM
zexifiedlude
Sep 5, 2006 05:38 AM
Suck my DX
Jan 9, 2005 07:21 PM
