how can i take bondo off???
You can always hope they did it the cheap way and used all bondo, you might get lucky and be able to break it out/or sand it down. If they welded in metal and then skim coated with bondo then you are best to not do anything good luck.
Have you seen those drill attachments for sand and paint removal? It's like a really really stiff and gritty sponge. They're about 8 dollars at autozone IIRC and attaches to a regular drill. I've used this method...ate the stuff off with a quickness. I'd suggest a little bit of research before you go hacking into this though. There's also a paint and body forum here on HT...not saying don't post here but the people there usually have a much better understanding of these things and might be able to provide you with better answers, alot quicker than we can.
It's called a paint/rust remover wheel IIRC...it's like a dark brown color it'll be next to the sandpaper in auto parts stores...
http://shop.advanceautoparts.com/web...ci_sku=7101627 here's a link for a picture ref.
^ Never heard that...you mind explaining a little bit of the method...and how well it worked...it might be more effective than my drilling for an hour.
577HondaPrelude
19
Apr 1, 2006 06:45 PM
jweezy225
Jul 11, 2004 01:02 PM
