Suspension & Brakes Theory, alignment, spring rates....
Vibration Problem>?
Old Apr 13, 2011 | 05:28 PM
rekreb's Avatar
Icon6 Vibration Problem>?
hi guys i got an 94 accord with h22 swap.My car has vibration problem at higher revs.Reason for this problem might be i drove the car without a steering wheel belt over a month then i started doing vibration at higher revs.When I am pulling it easy it doesn't do any vibration even though at high revs.On the other side when i pull it hard then front end vibrates crazy. I don't think it is about tires or alignment because i got new tires around 3 months ago and balanced them.Right after I got new tires i also did alignment as well. does anybody have any idea what i am talking about.thxxx
Old Apr 13, 2011 | 06:17 PM
pwebb0207's Avatar
Default Re: Vibration Problem>?
cheap CV axles
Old Apr 13, 2011 | 06:26 PM
rekreb's Avatar
so you think it is about the axles but i have recently changed the driver side axle.honestly the passenger side axle making noises while turning so i guess i have to change the passenger side as well then
Old Apr 14, 2011 | 07:34 AM
rekreb's Avatar
any opinion??
Old Apr 14, 2011 | 09:16 AM
OldSchool Honda's Avatar
Hmmm... reminds me of my integra wheel hopping when I launch it.
You said, without a steering wheel belt? As in powersteering pump belt?
Steering without the pump running could have caused parts to fail.
When you launch your car at high revs, you having to counteract torque steer/turning sharp could cause overstress on damaged components, possibly misaligning the suspension.
Old Apr 16, 2011 | 12:50 PM
iskate2's Avatar
have you visually inspected it yet? That goes a long way.
Old Apr 23, 2011 | 09:31 AM
rekreb's Avatar
I have finally figured it out.It is about front passenger side bearing.I have lifted the car and I realized that spindle doesn't hold the wheel tight enough.I also checked the bolts and studs they all look seem good.Probably the bearing is bad so I am gonna get new spindle with bearing in this week.Right after I replace it I am gonna let you guys know the results.By the way thanks for all your suggestions.
Old Apr 26, 2011 | 01:00 AM
blackedEk's Avatar
yea a bad hub bearing will cause vibrations during a certain speed..
you will need to rent some tools to get the job done, its pressed fit in there.
Or buy a used knuckle with a good known hub bearing and swap it in. GL
whiteformula98
11
Nov 9, 2015 06:58 AM
rekreb
May 7, 2011 09:48 AM
stalyun
Mar 19, 2010 06:42 AM
Midori Green
Aug 2, 2007 08:18 PM
Do_Ster
Jul 27, 2004 10:38 PM
