cylinder head gasket kit
Old Apr 12, 2011 | 09:43 PM
dylaxiin's Avatar
Default cylinder head gasket kit
when i rev my car over about 4000rpms it blows white smoke out of the exhaust, i need to know if i should just buy the full gasket kit or someone could tell me what the exact problem is so i can narrow my choices down to one. please help... thanks
Old Apr 12, 2011 | 09:55 PM
.Manny.'s Avatar
Touching My Member
Default Re: cylinder head gasket kit
Perform a leakdown test. Troubleshoot, don't guess.
If you're unable to perform the test yourself, have a shop do it.
Another easy way to tell if your headgasket is leaking is to check if oil and coolant are mixing. Looks like a milkshake under the oil cap and in the radiator.
Old Apr 13, 2011 | 07:05 AM
dylaxiin's Avatar
it doesnt look like a milkshake
Old Apr 13, 2011 | 08:20 AM
Nestorpants's Avatar
I agree with Manny. I have the same problem but I've narrowed it down to valve stem seals by testing. Not saying that's your problem too I'm just saying do the tests. You should also check the plugs for oil etc.
Old Apr 13, 2011 | 08:23 AM
Arthas's Avatar
Are you burning oil? Your oil is amber/black and your coolant is (hopefully) green???
Get a leak down test performed.
Old Apr 13, 2011 | 10:00 AM
dylaxiin's Avatar
I do know that the spark plug holes have oil in the them, but I still can start the car
Old Apr 13, 2011 | 10:01 AM
dylaxiin's Avatar
I know that my coolant and oil aren't mixing cause I just recently changed the oil and it was pure black
Old Apr 13, 2011 | 10:08 AM
4drEF's Avatar
Keyboard Humorist
Blown headgaskets can also leak from the coolant passage directly into the cylinder and never get into your oil.
Are you losing water in your radiator? Combined with your white smoke, that's a tell tale sign of a blown head gasket.
Compression check can usually pick up the problem... leak test would be better, but since you have white smoke you can get a test kit from your local parts store that detects exhaust gasses in your radiator fluid.
Larger leaks are easier to find as bubbles can be seen the radiator water when you take the cap off.
Old Apr 13, 2011 | 11:15 AM
dylaxiin's Avatar
Yeah it does seem that when I fill up the coolant reservoir it uses a lot of that. What is that test kit called, I'll probably go puck one of those up soon
Old Apr 13, 2011 | 01:13 PM
4drEF's Avatar
Keyboard Humorist
You can rent the tool at most parts stores and buy the liquid - looks like this;
http://www.autozone.com/autozone/acc...ester/_/N-25dh
Works like this;
http://www.blockchek.com/
Old Apr 13, 2011 | 02:41 PM
Arthas's Avatar
Ahh then theres your problem. My car had that problem till about a week ago I think.
Remove your valve cover and replace those seals that block oil from getting into the spark plug chambers. Theres 4 of em and I believe theyre like $1.50 each at Honda.
When you install them, oil them up first or theyll go in crooked.
Old Apr 13, 2011 | 07:04 PM
Jockone's Avatar
It's called a block tester,dark blue/purple fluid will turn a yellow/green if there are combustion gasses in the cooling system.
Cheap tool and very useful.
Old Apr 13, 2011 | 08:26 PM
dylaxiin's Avatar
So that's my problem, oil in the spark plug chamber. But if I remember correctly before I bought this car my friend drove it daily for like a year and it wasn't smoking nearly as bad. And the SP chambers were still filled with oil. It just smelled like gasoline inside the car. Before I bought the car it sat for 2 years
beat ignition
Honda Civic (2001 - 2005)
Jun 7, 2019 04:24 AM
alex1320
May 11, 2013 01:58 PM
thebleek
Oct 9, 2008 04:42 AM
nhsk84life
Sep 26, 2005 08:13 AM
