What Size is Right
Old Apr 12, 2011 | 05:52 PM
JDMmadness's Avatar
Default What Size is Right
ok so im turboing my 89 ef four door, i got everything but im not sure whats my best bet turbo wise. i have a garret 60/48, im looking for lots of mid range and high end power but is it going to lag like a beast?? should i go with a smaller turbo to get a quicker spool? if i go smaller i dont want it to run out of breath before my b16 does, and suggestions?
Old Apr 12, 2011 | 10:55 PM
W!d3b0dYr3X's Avatar
Default Re: What Size is Right
Do u have a hp goal in mind?
Old Apr 13, 2011 | 04:21 AM
4cylfiend's Avatar
The 60/48 are the housing sizes. Is the a/r .60 the compressor side? What size turbine and compressor wheel are you running?
Old Apr 13, 2011 | 04:26 AM
Turbo-LS's Avatar
for a b16 a gt3071 would do very well. it will spool good and give you decent mid range and great top end. really depends on yuor budget and the power goals in mind. If you dnot have GT money there are other options for you as well. Try to contact TheShodan on here and he can set you up with a god turbo for the application, but have your goals in mind and budget beforehand
Old Apr 13, 2011 | 07:13 AM
JDMmadness's Avatar
60 is compressor side and I'm looking fr around 250 or more on a save tune cause internals are stock. I have hondata s200 and dsm 440cc
Old Apr 13, 2011 | 07:19 AM
4cylfiend's Avatar
Ya you should be fine with that. The smaller exhaust a/r will help you with spool. You will have a pretty effecient setup using that turbo.
Old Apr 13, 2011 | 07:50 AM
TheShodan's Avatar
Moderator
250whp or more to the wheels won't cut it with a Saab turbocharger or straight T3 (250whp is about max at a good pace), but you have to have a budget (meaning maximum willingness to spend on the turbocharger itself), what the use of the car is, what equipment that you already have (in terms of manifold , dp, and use of A/C if possible), so that you dno't have to substitute for a lot of parts after you've chosen the turbocharger.
Since this is a stock engine you'll need to ensure that the motor cna handle the additioanl stresses that more power brings, (although 250whp is well within stock limits). So, don't forget making sure that compression/leakdown tests are in order, good maintainence schedule, etc.
A lot of us can help, but you have to have a vision and a goal in mind. just "oh 250+ hp", will not do.
Old Apr 13, 2011 | 08:37 AM
JDMmadness's Avatar
already done a compression test everything checks out good. i have a custom manifold 3in down pipe, tial wastegate, hks ssqv, small intercooler i think its 28x6x2 1/2 , 2.5 in int piping also have some 2in piping to go from the intercooler to the compressor.as said before dsm 440cc hondata s200 and a garret ar .60/48
Old Apr 13, 2011 | 11:15 AM
TheShodan's Avatar
Moderator
The Garrett .60/48 Sounds like a Saab turbocharger (some detailed pics will confirm or retract this), which will have difficulty of getting to that power level. The DSM 42lbs/min that you're using will be fine for that level, but if you want more, you'll need to change them out and retune, so take that into account.
Old Apr 13, 2011 | 11:27 AM
JDMmadness's Avatar
I'll upload pics later
b16boy95
Feb 25, 2011 09:21 PM
FlySi
Jun 6, 2003 08:16 PM
shermanyang
Mar 19, 2003 07:13 PM
Snafu-Si
Apr 27, 2002 12:46 PM
BlueSi2k
Apr 15, 2002 07:05 PM
