Transmission & Drivetrain Gearboxes, Differentials, Clutches
RSX transmission shift linkage question
Old Apr 12, 2011 | 11:38 AM
Longitudinal's Avatar
Default RSX transmission shift linkage question
Hey, it's been a while since I visited here.
I am building a K20A2 conversion for a Fiat X1/9 for an all-Fiat shop in Columbus, OH. I am working on shift linkage now, and would like to know if the housing on the transmission that contains the selector shafts can be removed as a whole unit without disturbing anything inside the transmission. I don't have the factory cable ends to use, so I will need to cut off the pins to which the original bushings mounted and drill and tap or weld for rod ends.
Any help is greatly appreciated. I just don't know what is under that housing and I want to ask before I move.
Old Apr 12, 2011 | 03:51 PM
David @ Synchrotech's Avatar
Default Re: RSX transmission shift linkage question
Yes you can easily remove the shift arm housing. Just put it in neutral first to align the forks.
Old Apr 14, 2011 | 07:20 AM
Excellent! Thanks.
Old May 6, 2011 | 06:42 AM
OK. Finally got down to doing this part of the job. I removed the four bolts that mount the housing to the case. The housing comes up a bit then runs into very solid interference. The unit is in neutral. Moving it this way and that doesn't seem to be able to free it from the transmission. Please advise.
Old May 6, 2011 | 06:56 AM
You will need to remove the 8mm allen plug on the side of the shift housing.
Old May 6, 2011 | 07:10 AM
Don't see an allen plug. There is a bar code and a number if it helps: XM25-1010131.
There are four 10mm bolts of two different lengths holding the housing in. There is also a switch of some sort held to the housing by three 10mm bolts. I have not removed this yet.
Old May 6, 2011 | 08:36 AM
No need to remove the solenoid. See # 8 in the pic below
Name:  RSX Shift arm.gif
Old May 6, 2011 | 09:04 AM
Figured it out. Didn't realize you meant that the plug was in the transmission housing. Thanks so much. The shifter mechanism is on the bench now.
Old May 6, 2011 | 12:21 PM
And done! I actually kinda like cable shifters compared to linkage rods. Had to build a reversing shift linkage since the engine is behind the driver, but it all worked out fine.
kornerk12
Mar 15, 2007 05:26 PM
jdm_Integra0369
Jun 9, 2006 10:54 PM
CivicRaping
Mar 25, 2005 05:47 AM
rasinhell
Jan 14, 2005 06:25 PM
Unjockable
Apr 24, 2002 10:13 PM
